848 Will Go On Gear And Spin When On Back Stand
Discussion in 'Ducati General Discussion' started by DRider, Sep 7, 2020.
  1. Is it stalling when you pull away? Defo check the switch if it is
  2. pretty sure it's mechanical? - from O.P. feedback anyway..
  3. But it goes in gear ok and runs on a stand, so if clutch was totally shot wouldn’t it either crying in on the stand or just stall when put in with the wheel on the ground?
  4. If the bike does not move when you let the clutch out but the revs still rise, sounds like the clutch is worn out.
  5. It would help if we knew the answer to my question #8 this might indicate a clutch problem.
  6. Has the clutch been taken apart recently?
  7. I will look into it will get back to you on this .. Thank you so much
  8. I will try as you said and let you know thank you very much..
