900ss 1e 2000 Model Alternator Nut Removal
Discussion in 'Supersport (1974-2007)' started by Simon Moore, Mar 6, 2018.
  1. Remember to get that green thread lock for re-install. The heavy duty stuff.
  2. Obviously a holding tool is better than using a coin but if you are stuck this works. You don't need an impact tool, a breaker bar will get it off. However it's very f'n tight.
    • Lock Thread Lock Thread x 1
  3. yes, can be very tight and the fact it's such a shallow nut it needs a good fitting full-hex socket with the starting chamfer ground off. I think we all started using a breaker bar but both the need to restrain the crankshaft plus the risk of slipping on the shallow nut can both be removed with above impact gun.
  4. I thought that this was a carby bike issue only?
  5. Even though it's s Nicol Engineering 2 part locknut arrangement he's planning to fit??
  6. I hadn't taken in that part. [​IMG] It'll just be 140Nm then.
  7. Which loctite thread locker to use?
