900ss Ie Help Needed
Discussion in 'Technical Help' started by firesorter, Feb 7, 2015.
  1. You should be able to blow through the tube backwards which partially pressurises the tank, and when you stop blowing it should his back out again............alternatively open the filler cap and then blow back through the tube again and see if there is resistance...........
  2. Guys thanks for the steer can't find any blockages still doing it however thanks to you i now have a cunning plan
  3. To wrap this up, after dismantling etc the issue has been resolved successfully
