916 916 Problems
Discussion in '748 / 916 / 996 / 998' started by duke123, Apr 14, 2017.
  1. thanks for this post. Mine started to turn over slowly last year, the sprag clutch has gone. Just in the process of getting the engine fixed and once its all back together. If i get any slow turn over or that the cables are not good. I am going to replace them. Thanks.
    vinnychoff
  2. A failed sprag clutch is a consequence of the motor not turning over properly.
    The original problem will still be there. You will need a decent battery and probably a cable kit to cure it.
  3. thanks i have a new battery and sorting the starter out. now i have read about the cables. that will be next.
    vinnychoff
