916 Restoration Project
Discussion in 'Builds & Projects' started by Iant187, May 21, 2015.
  1. I'd check it starts and run it but don't ride it, get it up to temperature and check the fan is running and switching on. After that a full service and then give it a good road test to see if there are any problems showing and rectify them if you need to.
  2. Yeah getting it started first is what I'm thinking, then I'll get a garage to check it over and do the belts and brakes etc... before I ride it anywhere!
    I'll let you know if it starts (once I've managed to change the bl00dy spark plugs!!) :)
    Cheers
