916 916 Sp3 #098
Discussion in '748 / 916 / 996 / 998' started by Guillaume69, May 2, 2022.
  1. Good stuff Guillaume. :upyeah:
    GB Motorcycle Products has a really good reputation, quality tools. I'll say it quietly...but in the past I've use 5 cent pieces to lock up gears so you can torque as required, dunno if it is possible in this case though.
  2. It would probably work, I have already read about this method.
  3. Got this wonderful magical (and sturdy!) tool yesterday. 70210764-5420-4B91-A6B9-A0851FEA3C8C.jpeg
    Which allowed me to torque back the alternator nut at 180 Nm with red loctite. EFA39E09-18D8-48F9-BFC4-2ED7661A2FEA.jpeg
    And button her up. She fired right away, always a pleasure… Set the injection right and this morning, I intend to go for a quick road test. Roads are dry, but with 3 degrees, it’s cold.
    On a side note, I was surprised at how much changing the valve clearances impacted the idle mixture. When I first started her, I found the horizontal cylinder was running fairly rich (AFR = 7) and the vertical rather poor (AFR = 20…). Adjusting the airbleed screws to get a steady and synchronized idle as well as the ECU mixture screw brought everything back in my target AFR range of 12.5/12.3.
    #163 Guillaume69, Dec 4, 2024
  4. And we’re done for this one.
    • Like Like x 8
  5. Went for a quick test (cold) ride today, 20 miles around our neighborhood and… well, works a treat!
    This is such a great bike. When comparing it to the 851 SP2, you can tell it’s the same motor, but everything about it is smoother, lighter, slicker, in a word, sexier.
    Happy life!! :D
