959 959/899 Suspension
Discussion in 'Panigale' started by flatstick959, Jul 4, 2016.
  1. How do you wear like that on grass?
  2. By being a legend ;-)
  3. Kick stand bolt.....mine had loosened a little, not much, but markings didn't line up.
    Read on another forum about them going loose, so just check if you hadn't already.
  4. I've been playing with my MCT Valved shock on a ride last night, I wanted it to soak up bumps better so reduced the compression damping down to only 0.5 turn for fully 'soft' and it's actually made the shock quite harsh again, it seems to move too quickly and a little uncontrolled (which makes sense I guess) so the sweet spot seems to be more like midway even with the MCT revalve, this gives the rear a plush feel and soaks up 'enough'
  5. mine is set to 1 turn out from fully stiff and he said that good for road and track
    the track settings in the owners book say to go half a turn out i think but will have play around with it
  6. Yeah I think I was at 1.5 turns out and was okay with it, so will go back to that, it's just to point out really that people seem to assume 'winding everything off' softens the bike, when in actual fact you need the suspension moving through the stroke at the correct speed
