999 clock reset issue
Discussion in '749 / 999' started by salmore, May 24, 2013.
  1. I'd suggest buying a cheap multimeter, it'll make diagnosing the problems a lot easier.
    If you're using the dash and we assume it's accurate, and we also assume the new battery is in top nick:
    The voltage when it's running is what you'd expect so I'll guess the generator/regulator is working however the dash won't tell you if it is or isn't charging the battery.
    The voltage when it's off isn't ok so I'd say you have a problem with either the earths to the battery or the power lead from the battery.
  2. Thanks I'll look into it, see if I can figure out which is the issue.
