848 Aftermarket Wheels - Light Ones ;-)
Discussion in '848 / 1098 / 1198' started by Fastmonkey, Oct 17, 2014.
  1. Interesting I only thought they were available for the 1098/1198's. Are they the same shape and style as the oem ones ? Weight differences ?
    I found these the other day PVM - Only available for the Panigale it seems from the Harris Website.
  2. As far as I'm aware there were offered as a a DP item and not standard oem.
    #43 Nelson, Oct 24, 2014
  3. Just mussing here..... Would it be possible to swap out the 848 hub/shaft/disc to accommodate the larger 1098 wheel?
    This would give you greater scope for finding a wheel and you get the big boy hub, which will make you irresistible to the opposite/same sex...:Kiss:
  4. Lovely......... however the only thing is they look pretty much the same if I was spending that much on wheels then I would probably want people to know that ;)
    With the 1098 wheel, that would be a 6 inch though wouldn't it so couldn't run a 180 ? Although I'm a fine one to talk as I had to run a 190 in Almeria as they had no 180 tyres !
  5. The "same"...!!!
    How very dare you!
  6. I should have added to the untrained eye............ My humble apologies....... ;-)
  7. I weighed the new design Dymag CA5 single sided rear wheel when it arrived at JHP.Big difference to alloy marchesini wheels
    BST also sell these for 1098/1198 etc bikes.Very nice.
  8. That swingarm is amazing..........
    This video is good, see matey chucking the BST carbon wheels around and bouncing them !
