916 Another Cam Belt Thread
Discussion in '748 / 916 / 996 / 998' started by Akorenika, May 24, 2020.
  1. The picking up a Van comparison was a bit tongue in check but showed surprising results of the CCW belts - but Chris did a massive amount of lab based R&D along side that too. His point was that launching a Ducati Belt 10 years ago against OEM he had to make sure his were engineered the best they possibly could be - so he didn't cut any corners. He also had a technical partner in the Ex Tech Director of Gates.
    +10 years on and history shows they certainly got it right...
  2. I used to work for both teams. The boys are cheapskates
  3. They don't buy Gates :p
  4. Unfortunately the link doesn't work on my equipment. I try at a later point from a different computer.
  5. I think he put the wrong link up :thinkingface:
  6. And there is every chance I will have to beg you to sell me a set of belts.
  7. I Googled California Cycle Works belt test
  8. Scroll down to the bottom of my home page - there are some video's there: www.ducati.tech
  9. Nice response Akorenika, you're going to fit in well here:)
  10. Ha - doesn't work for me either -apologies. Google is your friend....
  11. Exactfit belts are proven to be high quality, premium replacements. You also pay a premium to buy them. End of.
    This comparison should really only be for OEM Ducati belts, which are branded as Gates Powergrip HTD, vs the Renault belt of the exact same dimensions, also branded as Gates Powergrip HTD.
  12. He is so confident in the belts he sells, I am sure he would donate a set for your tests.
    • WTF WTF x 1
  13. Clip not found sadly.
  14. If he was to donate a set I'm afraid I would just fit them and say no more about it. Although I'm very curious by nature I have short arms and deep pockets.
  15. Another Yorkshire lad, you and Exi will get on fine.
  16. Exactly why I did not mention them, but the talk was around testing which is where the CCW connection came in :)
  17. I was just going to say I'm Yorkshire remember :bucktooth:
  18. FWIW ....
    I've been digging through ancient notes ....
    I can see that I've used Ferodo belts in the past , and also these
    " FLENNOR "
    made by Walther Flender Gruppe and marked as 58093 x 17mm
    .... also 4 07 3DS ( which was probably a batch number )
    Both sets were probably bought in France .... I did a quite lot of mileage while I was living there !
    #58 oldtech, May 27, 2020
  19. Interesting that there are so many alternatives. For my purpose I'm only going to try to prove that the OEM belt(made by Gates)and the Gates Powergrip 5192 XS are the same.
  20. Any update on this one?
