848 Are Zard Exhaust Any Good?
Discussion in '848 / 1098 / 1198' started by charliem749, Aug 12, 2014.
  1. Found a set of akra's on eBay :upyeah: does anyone know if I will have to get the Ecu re-flashed or if they will work with the standard Ecu & filter?
  2. good for you! you'd have thought so but i remember someone saying they didn't???
    let's see what @bradders has to say. he had some on his evo. they did look the business! ;)
  3. Of course the bike will run. However I suspect it will run lean and be jerky on the throttle. This is what happened with my cans on my monster. Ended up having it mapped by cjs. Made it a different bike.
  4. You'll be fine. Mine was. Ideally get at least a simple DP flash. But I didnt. CJS did mine eventually, and took a DP flash from 131 to 139 on an evo
  5. I didnt find that. It ran fine, a little cough occasionally on off/on throttle type activity but no issues
  6. So I should be fine running them with the standard Ecu for now and eventually get mine re-flashed? How much is a re-flash?
  7. I did no prob, most do
  8. Btw best looking and sounding cans on an 848. Fact
  9. [​IMG]
  10. Second that about sc projects, I have a cr-t stubby on my hyper and it is quality kit, sounds bonkers too, highly recommend them...Italian made lovelyness
  11. Got the akra's fitted yesterday, look and sound amazing :) Thanks for all the advice :upyeah: image.jpg
  12. look mint!
  13. Cheers mate :) I've noticed a change in the rev range, seems to be sitting about 500 rpm higher at the same speeds as with the standard cans! Has anyone else found this with slip on's?
  14. Errrrr WTF, that's upside down :Woot:
  15.
  16. They are flat to the top otherwise they are DRAZ slip ons .....
  17. Sorry to butt in.
    Just to comment, sold a set of the SC's carbon end cans, customer loved them. Great value for £530 brand new
