Basket Case
Discussion in 'Supersport (1974-2007)' started by ck_uk, Dec 10, 2019.
  1. Can't remember the exact chemistry now (used it a lot in an old job decades ago), but cold chemi-blacking works by making the outer surface slightly porous (maybe it's a ferrous-phosphate layer? not sure) and thus able to hold a thin film of oil as an anti-corrosion device. It's not as good for this as hot chemi-blacking though. You'll need to keep the part lightly oiled to maintain corrosion resistance (like a shotgun barrel). It's for a dry clutch, so light oil next to clutch surfaces - um...:thinkingface:. Apologies for the vague chemistry:laughing:
    Edit: A quick chat with Wallwork should be the best info about corrosion resistance and maintaining that...
    #21 Keith_P, Dec 12, 2019
  2. Is it worth it?
    Although I am one who is terrible with money and loves to spend on my bikes ;)
  3. As previously suggested, give it a good rub with a wire brush followed up with 10 minutes rubbing down with wet n dry and soapy water, give it a good drying, hang it up and spray on a couple of coats of satin black, it'll come up mint and cost you about 50p. Job done..
  4. This sounds a far more economical solution on a used basket
