Battery Upgrade To Bigger Advice
Discussion in 'Ducati General Discussion' started by Gary gibb, Mar 3, 2017.
  1. Thanks for all advice
  2. AGM batteries are a lot stronger than conventional lead acid - the Yuasa is actually 210CCA.
    Your engine is a 4-stroke
  3. You should be able to return any on line order for refund with no fuss?
  4. Work with batteries all day. Lithium are too weak IMHO and dangerous
    Sealed Lead acid is the way to go with 200 + CCA
    You can up rate your cables for around 15 quid here
    Battery/Starter Cable
  5. Lol inline 4 i should have said
  6. Cables for 15 quid where
  7. Of course there are options for 'cheaper' cables and you can make your own up. Mine are upgrades - not replacements. I only supply the best (which don't require you to cut your Battery Box lid up as all terminals are designed specifically for the bike)
    Read my specifications on the web site and make your choice :upyeah: ExactUK
  8. On the page shown, Measure your current lengths for + to Solenoid and Solenoid to Starter. Maybe add a second earth
  9. thanks lads i can make my own no probs will buy the lead canle heavy duty and get them sorted up cheers
  10. Yep that's what I did
  11. Buy cheap buy twice...
    Exige's cables are made to railway industry standard and are a purpose designed kit made to fit your bike perfectly with bike-specific instructions.
    Yer pays yer money and yer takes yer choice.
    #32 Old rider, Mar 3, 2017
    • Disagree Disagree x 1
  12. You don't recommend Absorbed Glass Mat batteries then - love to hear your reasons...
  13. Let me know if you need any help / info :)
    If you need advice let me know - I have a picture of where to cut open your battery box lid from a customer who fitted his own and ended up buying my cables - and a new battery box lid.
  14. Once i have cash i will just buy from you so there ready to fit
  15. Either way I'm on this Forum for enjoyment, advice and to help where I can :upyeah: just let me know on our PM - good luck with the battery
  16. Wise choice :upyeah:
  17. Will my bike pull like a if I buy them?? Choo choo
  18. you will become incredibly attractive to wimmin, and if you're a wimmin, incredibly attractive to wimmin too :Hungry:
    :Writing:probably...
  19. Mine have been on 5 years and are still going strong. You could put graphene on there and it would last longer and do a better job. But the gains from that or and so called super grade cable over a distance of less than meter boil down to three or four decimal points.
