749 Battery Woes
Discussion in '749 / 999' started by Mike1981, Oct 13, 2018.
  1. This one's for you, Bob!
    : o D
  2. Can someone confirm the SL and the exact same part number as the "normal" Pani?
    I assume the "normal" pani has a standard lead acid battery?
  3. The Shorai has a special socket to connect a balancing charger.
  4. My second generation 1199R came with a Lithium battery and charger from new...
    • Disagree Disagree x 1
  5. Oh yes it did Lozzeraptor... :thinkingface:
  6. That isn't a charging unit, you daft old geezer.
  7. It is :eyes:
  8. Not.
    I had one similar and it just discharged everything.
    Thank Goat for Fabreeze, am I right?
  9. I did give it a squirt :blush:
  10. Do you have to plug in?
  11. I run on Lithium, one squirt and bang :bomb:
  12. You romantic old fool.
  13. As long as your timing is not over advanced (premature)...
  14. What a brilliant end to a battery thread :innocent:
