Bevel Carburation Issue ? Hot Horiz Cyld Silencer
Discussion in 'Vintage' started by Dodgy Dave, Dec 20, 2015.
  1. bugger, just read your comment that both headers glow red!! Yes don't run the engine too long stationary,,, or place a fan in front to help cooling,,, how does the engine pull when riding through the gears? (after carrying out an oil change if the engine has stood for years)
  2. Cheers Q and HNY ! Oil and filter changed, magnetic pick-ups fitted to every orifice, 99 RON fuel in tank, carbs spotless, so just waiting for anything above 8 degC to give it a spin !! I spotted an interesting U-tube clip about how to set the air slides, using little more that lug-holes to tell when the slides clonk down, so tried that for starters. I have the Carbtune ready and waiting; and the see-through viewing plug is winging it's way to Drax _ will keep you'all posted !! Best Wishes to all Bevelers - dp
  3. Admittedley it was much easier on a Guzzi Le Mans to get the slides to open and close at the same time, because you could see them at the same time..........but as I am a short*rse, I couldn't reach the throttle while standing right at the rear of the bike to get a straight-on view of the slides.........so with the seat off, I balanced (pun) a small bathroom cabinet with a mirror across the frame tubes and held it in place with two bungees........that way I could stand at the front of the bike, looking in the mirror and working the twistgrip.
