Brake Upgrade For A 749
Discussion in 'Ducati General Discussion' started by JohnnySea, May 22, 2023.
  1. interesting as I’ve just bought a speed triple that comes with Stylema’s and a ratio adjustable MC from the factory, the ratios are 19/20/21 so I’d be surprised if 17mm was optimal
  2. Are you sure that’s not lever offset/ratio rather than piston size (never heard of variable piston m/cylinder).
  3. On a Ducati with MCS (as fitted to the SP2), the 19-21 only refers to the distance the shaft is from the pivot. It doesn't refer to the piston size. And, I believe the piston size is 17
  5. niiiiiice
  6. What reservoir did you use for this upgrade?
  7. The OP hasn’t been on the forum for more than 3 months, @JohnnySea. Andy
