For Sale Breaking 1994 600ss
Discussion in 'Parts, Accessories & Clothing For Sale' started by sharpypaul, Apr 23, 2016.
  1. whats left on the engine ? And how much?
  2. The engine is complete, no bits missing. The barrels have been removed but they're still there. Needs to be collected from Southampton, PM me an offer and we'll go from there :D
  3. Thanks Paul
    The bit that goes on the wheel end.
    Cheers
    Neil
  4. Thanks, It's just the lever that's needed.
    John
  5. Got a pic of the gearlever?
    PM sent. Cheers
    Rob
  6. Hi John, are you still interested in the fairing frame, right hand riser and mirrors? If not how does £6 for the lever sound?
  7. Hi Paul,
    I'm interested in the headlight if you've still got it & it's a pukka UK model. I'm also after the aluminium bullet thing that holds the rear panels on or the complete handrail if you won't split.
    Also interested in the airbox top or complete airbox if it's not been modified.
    Cheers
    Paul
    #27 paul1098, Apr 26, 2016
  8. Hi Paul, yes I do still have the headlight and it is a UK one :) The air box is standard and ready to go complete for you. Not sure what you mean about the aluminium bullet thing, I will have it, just need to work out what part it is! The handrail isn't attached to it so that doesn't help me out!
    Paul
  9. Hi Paul,
    The aluminium bullet things screw into the back of the grab rail and the rear side panels slide over them. Hope that explains it better. How much do you want for the above?
    Cheers
    Paul
  10. Sorry about the delay Paul, I didn't get an email notification somehow.
    I'd definitely want the lever, and the rh riser. I see my fairing frame is OK, really, one small floating down tube missing - but I don't have the fairing fitted any way - I could get it welded up if I ever fit it (with the mirrors). Give me a price for each and all anyway, I'll see how much spare dosh I have at the beginning of the week.
    Cheers,
    John
  11. No worries, some of my messages don't seem to be sending as well, it's all very confusing! How about £35 for the riser and lever including postage? I do have to work out how to separate the lever from the brake reservoir otherwise you're getting that thrown in!
    I'll have a look tomorrow
  12. have you got rid of the tank?
  13. I'd give you £25 for the two including postage Paul. Tell me how you want them money sent... you could pm me your bank details for a transfer.
    The lever detaches quite simply I believe.
    John
  14. Hi, the tank is still available, I'll take a photo of it for you :)
  15. please do! pm me a price if you like
  16.
  17. @sharpypaul Please advise when everything has been sold:)
  18. Will do :grinning:
  19. Hi John, sorry about the delay in replying. The lever did detach easy! When I took the riser off the bolts sheared, I've tried drilling them out myself but my drill isn't man enough! I can let you have them for £20 if you want so you have £5 to put towards having it drilled and tapped or I can try to have them drilled and tapped for you for the original £25?
    Let me know what you think.
    Thanks
    Paul
  20. Thanks Paul. OK I'll give that drilling and tapping a go. Send me your payment details.
    John
