Brighton Hove Ducati rides
Discussion in 'Rideouts & Events' started by slumdog, Jul 31, 2012.
  1. Could you google map burry hill for me only times I been there was fallowing Chris and all he did was point to old clocks on building on the way :D
  2. I might see who ever goes to bury before hand.
    All depends on weather
  3. #23 CRYSTALJOHN, Aug 3, 2012
  4. Going straight there as bury isnt an interesting ride from here
    Going via petworth if weathers ok
  5. Ok D, I'll be going to Burry hill from home. Aim to be there at 930 max
  6. The weather in eastbourne at the mo is ok.Hope its the same tomorrow. Hope to find some of you at Goodwood.
  7. I'll see u if weather doesn't change :)
  8. See you all at Goodwood, probably going early.
  9. I'll go to goodwood directly then. See you all there.
  10. Got as far as Storrington wet roads black sky west. Now at the Chalet A281 Cowfold.
    #30 keninsussex, Aug 5, 2012
  11. Got soaked but as was half way there it was to late to avoid rain so did not turn around, Chris :). Well worth it weather turned out ok, sunny even at moments. Meet biker babe, other Chris, John came by car. Nice day.
  12. I didn't 'avoid it' either L - worst had passed by when you arrived a couple of hours later - did i miss any nice clocks? :wink:
  13. Well then as you were wet you could have continued :) I did, when I stopped for petrol two guys at station were putting water proof on. They asked about my waterproof jacket if it is good. I said what waterproof jacket and rinsed it down then added I imagine there is no rain :) No clocks but seen one nice Russian "Clock" with English boyfriend ;).
  14. yeah, straight into the nearest tree - I wear 'specs' don't forget. So Russian clock would give 'good time' then? :)
  15. Few picture from the day:
  16. Good to see you guys there :cool:
  17. [​IMG]
    Sorry couldn't make it Sunday started early to change the oil and filter filter and this happened ! A case of the previous owners dealer over tightening ! All done now after a considerable PANIC !!
    #37 slumdog, Aug 6, 2012
