Case savers can anyone identify
Discussion in 'Technical Help' started by duc904red, Jan 17, 2013.
  1. [​IMG]
    Streetfighter though not tried it yet - hopefully soon when I do slave
  2. Cheers Char one of the fabled titanium jobs
    Steve B
  3. The 1100 and DS1000 ones may be the same, heres my sportclassic one (I haven't fitted it yet so cant tell how easy it will bolt on yet.)
  4. thanks havent got one of those
    big ask but could you take a paper pattern off it?
    ta Steve
  5. Char thats an odd rule you are using there l think it is meant for scaling
    Steve
  6. [​IMG]
    Yes wrong side sorry !
  7. how wide is it char
    looks like a 900 one maybe they are the same
    trying to rationlise
    not got all Darren's notes
    Steve
  8. [​IMG]
    I can check next week to make sure it fits ok
    I am happy to send it back to you then if you need to take a template
  9. The ?? one with the cutaway is the same as the one on my ST4s, also fits my 907. It should also fit any of the 3-phase cases from the early 2000s. I think the cutaway is to clear the later clutch slave.
  10. A scale rule it is.......got about 12 of them....commonly used by architects and draughtsmen (Well, those that can still draw on paper, that is).......For Char's pic, use the 1:1 / 1:100 side....all small divisions are in millimetres.
    AL
  11. Darren sent me one for a 749 but I had problems fitting it. I hesitated contacting him as I wanted to try and fit it again and unfortunately, what happened happened. I can take photos of it if wanted.
  12. If I were you, post a couple of pics of the saver and a couple of the case so we can see where / why it doesn't fit.........maybe someone can sort it for you.
    AL.
  13. This is what Darren said to me about the cut outs.
    The only real difference between the 1100 Hyper/Monster saver & the dry-clutch ones are the top tab fixing points and a cutout to clear the nubbin/lump between the slave and the sprocket shaft, they are on all reality a modified dry-clutch design.
    Mike
  14. Cheers Al, I think that it needs a cut out but I'm going to give it another go myself as I'm scared of Mr.C having another rant! :smile:
  15. Mikesps l think you are right just fitted the 1100 evo saver on my 888 no prob this means it will fit
    all that series 748/916 900ss/mon st2 cool product rationalisation
    thanks Steve B
  16. Hi Steve, assume by the above you are ok for the 998 variant (guess same design, fitment, etc as 748-996), or do you want pics?
    pete
  17. Steve,
    Your in box is full.
    Are you making case savers now?
    After one for my 1098.
    Thanks :smile:
  18. case savers will be avaliable by the end of the week for most models small and large crankcase
    regards Steve
  19. Must have item too imo!
