Check This Pump Out
Discussion in 'Clothing, Gadgets & Equipment' started by Sam1199, Mar 2, 2025.
  1. Yeah - not bad, ive only had to use it once....that being said and being very honest im not sure the tyre pressure reading is totally accurate (i set it to 36 psi) and it went off (indicating that it was at pressure) - i didnt have anything else to test (as i was at work at the time) so i just set the pressure to 100 and it started working. In essence...it does the job.
  2. FYI, I would recommend discharging every 6-9 months if it is for backup
  3. FYI, Kind of spins it out then bails at the end but comes up with 4 for 20 PSI
  4. How did this work out for you @Sam1199?
