1200 DVT Clocks Scratching
Discussion in 'Multistrada' started by Wayne58, May 8, 2017.
  1. It's like your's but less shonky and much faster !! :p
  2. Yey...Jimmy Tarmac back in the house.....!!
  3. Dont worry...found it....the hyper has a slightly matted clock/screen finish....i trust it wont affect that??
  4. Just bought it for my 1199... Will report back...On Amazon btw if you're a click junkie.
  5. Zaino Z14 buddy....you can get it from www.cleanyourcar.co.uk
  6. yes it will alter the finish ever so slightly as it is a very mild abrasive....
  7. Is that dust maybe from lack of use :bucktooth:
  8. Whoooo!.............sarcasm. :)
  9. Another great re-read.
  10. They are out of stock, is the Meguires Plast-RX any good?
  11. You can get screen covers like for a smartphone, to protect the screen, put one on my monster when new in Dec 2018, it's still on there. I believe it came from R&G racing.
    To remove the scratches you could try autoglym fastglass plastic polish, you can get this in Halfords.
    I use it on my visor and wind deflector, little and often seems to work best.
  12. Not sure about screens on other Ducatis but my Mutley 1260s has a slight curvature towards the edge of the screen. I have had two screen protectors and both started, after a bit of time and exposure to the elements, to peel at the edges. This grew to such an extent that I wound up removing them. Now running without but have some Z-14 that I bought for the dash of my MV just in case. The curvature seems to add tension, add some heat cycles and some rain and they start to lift. If someone like speedo angels recognised this and just made the protector a little smaller (not 100% coverage granted) this wouldn't happen.
  13. I had to buy on Amazon - and its a bit more expensive :(
  14. According to the installation instructions from Speedo-angels there is a 2-3mm gap around the edge of the screen to allow for fitting errors and to also help prevent the protector from lifting / peeling off.
    Ally
  15. Correct! Mine has been on over a year on MTS and for far longer on the Scrambler and it's doing what it claimed. Seems like a good product.
  16. I had some scratches on my Puig screen and used some Halfords foam rubbing compound. Its a mild foam based compound in a spray can. It worked a treat on the screen applying it with a wet cloth and got rid of the scratches. Not sure if it would work on the dash mind but maybe worth a try. Its not on their website but the item code is 451633.
  17. The gap didn't seem to help me with mine, followed instalation instructions to the letter both times. It was the nano glass protector, maybe less flexible? To their credit Speedo Angels did send a replacement when I complained. Maybe I should have another go...
