899 Coolant Drain Plug
Discussion in 'Panigale' started by gt_lad, May 19, 2018.
  1. Out of the 3 bellypan bolts, one is a different length and maybe a different shoulder length, take them all out, the 2 the same go at the back and the other goes at the front. I am going from memory so i may be wrong.
    Edit, also check the ones by the rearsets are fitted correctly as you may have put a wrong one in there.
  2. Yeah you're right, the two at the rear are the same but the one at the front is different again from memory, but I'll double check shortly. Thanks for the continued help!
  3. did we cover the one on the plastic sump guard? the one most rearward is hidden and may be missing?
  4. p.s. what was the prize again?
  5. Wasn't aware of that... I'll check. It's the last place I can check now, I can't see where else it can be?!
  6. Well nothing fell off in 1250 miles... I'll keep it handy going forwards... Just in case!
