1198 Do You Run On Premium Or Standard Unleaded Fuel?
Discussion in '848 / 1098 / 1198' started by Ben Mallinson, Apr 4, 2016.
  1. Pete, the 1950 in your name ... is that the year in which you were last wrong?
    • Funny Funny x 7
  2. Try 100 octane avgas, aviation fuel if you think that higher octane is better, it used to make my all of my cars run like pigs, but I used it because it was free. They all ran better on 95 as they were designed to.
  3. It couldn't have been free as you'd have to inform HMRC that you were using it to fuel your cars (or the French equivalent of HMRC) and pay the duty.
    I'm assuming you'd never break the law Bob !
  4. Mine seem to be better on premium. Wish it wasn't the case but I am pretty convinced
  5. Do we know what other fuels are ethanol free?
    Esso etc?!
  6. What's worse than being condescending?
    Being condescending in a different font.
  7. If your bike is stock and set up as it left the factory, running it on higher octane fuel could indeed make it run better as the factory set up is hardly that precise. In the old days they were often set up to pass emissions tests and the low-mid range was leaned out a touch meaning anything that improved that area could make the bike seem to run better. Bikes or modern cars with Lamda sensors will negate much of the perceived performance variations within a few miles (but not immediately which is when we assess the performance changes) once the ecu has "learned" the new fuel and burn characteristics. In the short period before that happens you may see or feel a change. If you make your assessment in a modern car based on the change in performance during the first 50 or 60 miles you are fooling yourself as the system will correct for the fuel properties but it takes time, longer if the lamda sensor is old and it could take a few days depending on your driving.
    It is also possible that fuel consumption can change as a result of using higher octane fuel which could be either a more efficient burn or simply the effective map changes resulting from a change to the burn rate of the fuel. If however you have set a bike up precisely then you should run it on whichever octane fuel you set it up with. I used to believe the "smoother running" was and indication of better burning, in reality on my bike the system was running slightly off optimum and the smoothness of running was slightly less precise combustion and slightly less power, although this felt like it was running better due to a slight reduction in vibration and less crack in the exhaust note - a dyno test would probably prove otherwise.
    I think Pete has the answer for most people - it is mostly in the mind. As for avoiding Supermarket fuel, that may wise for at least 1 of the major brands but most of them sell the same fuel supplied to the franchised garages only its cheaper.
    You pays your money and all that
  8. Morrisons finest for me.
  9. The one point that NEVER comes up in these conversations (although the points around ethanol are solid ones!) is that if a given petrol station sells 100 gallons of super unleaded a week but 1000 gallons of regular unleaded, there's a chance (a slim one but I'm trying to convey a point) that the super will have degraded to nearer the 95 octane of the 'fresh' unleaded, although this would in reality take a few months, u get my point.
    Generally the feeling in these threads is always that as long as u avoid supermarket brands you are generally okay, often people like bp/esso put in other cleaners etc that are good for the engine, so it's not all about the octane rating.
  10. For me, as I probably use 100% throttle less than 1% of the time I'm on the bike, normal bog standard unleaded would usually do. The ONLY reason I use BP Ultimate is the no ethanol factor.
    My Streetfighter S plastic tank warped, and I'm convinced it was because of that bloody stuff. It was changed under warranty, but as the warranty has expired, I don't fancy replacing this one out of my own pocket. Another couple of pennies per gallon is OK by me.
  11. More than 90% of the fuel I use is from one particular Tesco garage. I have never had a bad tank of fuel from there.
  12. Loz, Tesco are the only one I don't use due to long running issues with cars that had to run on higher octane fuels (a Lancia, Alfa 75 and an Impreza), awful running on 95 and 10% or more reduction in mpg on the high octane stuff. Although part of the reason is the rudeness of staff at my local in the past:rage:. Never had similar issues with any other brand, the Impreza was particularly sensitive but that never had issues with fuel from other supermarkets as long as it got 97 or higher. I don't think you need to constantly run the expensive fuels with additives except maybe occasionally.
  13. Interesting. Maybe I've just been lucky with the Tesco branch I use.
  14. I was under the impression that to benefit from 98RON etc, assuming that the manufacturer states that 95RON is what the engine was designed to run on, takes a knock sensor that can adjust/optimise ignition timing to suit, and take advantage of, the higher octane fuel. I believe that the DVT has one, not sure about other models. Otherwise you're paying for nothing extra in terms of performance.
    I accept that the potential for lower ethanol content may also be a consideration. However, modern fuel systems should be designed to cope with 10% ethanol fuel over the expected life of the vehicle.
  15. I don't own any modern engines! ;)
  16. If I pay the extra and buy Premium I always buy it from a garage that looks like it has a high turnover of fuel.
  17. No it was free, I worked in the aviation industry in the UK for all of my life. We had to to draw off a few litres of 100 octane from each bowser a number of times a day, and that fuel would get disposed of.
    I considered telling HMRC about it but assumed that they would make me pay 50% duty on it, well 50% of zero is still zero so I didn't bother.
    Besides when I bought road fuel for my microlight and never used that on the road HMRC never gave me anything back. Could not use the 100 octane in that though.
  18. Just noticed the forum that this is in :Banghead:
    Apologies. Though the knock sensor argument is a valid point, you just don't have one :)
    Nothing to be gained other than lack of ethanol and a bit more real fuel...
  19. The last time I checked, these Total Garages were Ethanol free - but check the pumps to be sure :)
    TCS Wheatsheaf
    London Road
    Virgina Water
    Surrey
    TCS Woodville
    Burton Road
    Woodville
    Swadlincote
    Derbyshire
    TCS Roundway
    London Road
    Devizes
    Wiltshire
    BATH ROAD SERVICE STATION
    BATH ROAD
    CHIPPENHAM
    WILTSHIRE
    TCS Elmtree
    Wells Road
    Radstock
    Bath
    Avon
    SOVEREIGN SERVICE STATION
    LONDON ROAD
    CHIPPENHAM
    WILTSHIRE
    TCS Viscount
    Burnham Road
    Highbridge
    Somerset
    TCS Stopsley
    619/621 Hitchin Road
    Stopsley
    Luton
    Bedfordshire
    TCS Cathedral
    3a Cathedral Road
    Cardiff
    South Glamorgan
    DUNLEY SERVICE STATION
    DUNLEY
    STOURPORT ON SEVERN
    WORCESTERSHIRE
    FALCON SERVICE STATION
    DAISY FARM ROAD
    YARDLEY WOOD
    BIRMINGHAM
    WEST MIDLANDS
    JOHN HARRISON (LOWDHAM)
    SOUTHWELL ROAD
    LOWDHAM
    NOTTINGHAM
    NOTTINGHAMSHIRE
    IVY GARAGE
    RYKNELD STREET
    ALREWAS
    STAFFORDSHIRE
    LAKE STREET SERVICE STATION
    45 LAKE STREET
    LEIGHTON BUZZARD
    BEDFORDSHIRE
    WEDNESBURY SERVICE STATION
    BILSTON ROAD/HOLYHEAD ROAD
    WEDNESBURY
    WEST MIDLANDS
    TCS Cross Hands
    Llandeilo Road
    Cross Hands
    Lianelli
    Dyfed
    TCS Roundabout
    New Inn
    Pontypool
    Gwent
    TCS Coalville
    250 Bardon Road
    Coalville
    Leicester
    Leicestershire
    TCS Ducklington
    Ducklington Roundabout
    Witney
    Oxfordshire
    ETWALL ROAD SERVICE STATION
    ETWALL ROAD
    MICKLEOVER
    DERBY
    DERBYSHIRE
    TCS Southam
    Banbury Road Island
    Southam
    Warwickshire
    TCS Chantry Fields
    Le Newborg Way
    Gillingham
    Dorset
    TCS Painswick Road
    191 Painswick Road
    Matson
    Gloucester
    Gloucestershire
    TCS Precinct
    Link Road
    Yate
    Avon
    TCS Leominster
    Ridgemoor
    Leominster
    Herefordshire
    TCS Viaduct
    138 Worcester Road
    Kidderminster
    Hereford and Worcester
    THRUSSINGTON SERVICE STATION
    663 - 667 FOSSE WAY
    THRUSSINGTON
    LEICESTER
    LEICESTERSHIRE
    TCS Birchley Park
    Wolverhampton Road
    Oldbury
    Warley
    West Midlands
    TCS Crossways
    Haven Bridge Road
    Honeyborough
    Neyland
    Dyfed
    TCS Cardiff Gate
    Junction 30 M4
    North Pentwyn
    Cardiff
    South Glamorgan
    LETTERSTON FILLING STATION
    18 HAVERFORDWEST ROAD
    LETTERSTON
    HAVERFORDWEST
    PEMBROKESHIRE
    DYRHAM SERVICE STATION
    ROBESTON WATHEN
    NARBERTH
    DYFED
    BARBROOK SERVICE STATION
    BARBROOK
    LYNTON
    DEVON
    ABERDARE SERVICE STATION
    NEW CARDIFF ROAD
    ABERDARE
    MID GLAMORGAN
    TREHARRIS SERVICE STATION
    CARDIFF ROAD
    TREHARRIS
    MERTHYR TYDFIL
    MID GLAMORGAN
    TONYREFAIL SERVICE STATION
    62 -66 MILL STREET
    TONYREFAIL
    PORTH
    MID GLAMORGAN
    IVOR MILES OF HADDENHAM
    CHURCHWAY
    AYLESBURY
    BUCKINGHAMSHIRE
    TCS Windrush
    Bath Road
    Padworth
    Theale
    Berkshire
    MAPPERLEY PLAINES SERVICE STATION
    MAPPERLEY PLAINES
    ARNOLD
    NOTTINGHAM
    NOTTINGHAMSHIRE
    HAUNCHWOOD ROAD SERVICE STATION
    HAUNCHWOOD ROAD
    NUNEATON
    WARWICKSHIRE
    C & A FILLING STATION
    BROADWAY ROAD
    WINCHCOMBE
    CHELTENHAM
    GLOUCESTERSHIRE
    CROOK FILLING STATION
    NEW ROAD
    CROOK
    COUNTY DURHAM
    BELLS CLOSE SERVICE STATION
    FRONT STREET
    LEMINGTON
    NEWCASTLE UPON TYNE
    TYNE & WEAR
    CHAPEL HOUSE SERVICE STATION
    HILLHEAD
    PARKWAY
    NEWCASTLE UPON TYNE
    TYNE & WEAR
    MILL LANE SERVICE STATION
    MILL LANE
    HEBBURN
    TYNE & WEAR
    SHIELDFIELD SERVICE STATION
    STODDARD STREET
    NEWCASTLE UPON TYNE
    TYNE & WEAR
    BOLDEN LANE SERVICE STATION
    BOLDON LANE
    SOUTH SHEILDS
    TYNE & WEAR
    TAMWORTH ROAD SERVICE STATION
    TAMWORTH ROAD
    LONG EATON
    NOTTINGHAMSHIRE
    MATLOCK ROAD SERVICE STATION
    MATLOCK ROAD
    CHESTERFIELD
    DERBYSHIRE
    BRIERLEY SERVICE STATION
    HIGH STREET
    BRIERLEY
    DRYBROOK
    GLOUCESTERSHIRE
    MALTHURST REDCAR
    TRUNK ROAD
    REDCAR
    CLEVELAND
    THREE B'S SERVICE STATION
    THORPE ROAD
    MIDDLETON CHENEY
    BANBURY
    OXFORDSHIRE
    WOLLATON SERVICE STATION
    WOLLATON VALE
    NOTTINGHAM
    NOTTINGHAMSHIRE
    MARTINS OF ANDOVER
    50 LONDON STREET
    ANDOVER
    HAMPSHIRE
    JAMES BRIDGE GARAGE
    HEATH ROAD
    WEDNESBURY
    WEST MIDLANDS
    DUNHAMPTON SERVICE STATION
    WORCESTER ROAD
    DOVERDALE LANE, DUNHAMPTON
    STOURPORT ON SEVERN
    WORCESTERSHIRE
    AUTOGAS SERVICE STATION
    EVESHAM ROAD
    ASTWOOD BANK
    REDDITCH
    WORCESTERSHIRE
    DORDON SERVICE STATION
    WATLING STREET
    DORDON
    TAMWORTH
    STAFFORDSHIRE
    DRAYTON SERVICE STATION
    WATLING STREET
    FAZELEY
    TAMWORTH
    STAFFORDSHIRE
    WALCOTE SERVICE STATION
    LUTTERWORTH ROAD
    WALCOTE
    LUTTERWORTH
    LEICESTERSHIRE
    SUDBURY SERVICE STATION
    LICHFIELD ROAD
    DRAYTON IN THE CLAY
    ASHBOURNE
    DERBYSHIRE
    M G GARAGES
    486 BORDESLEY GREEN
    BIRMINGHAM
    WEST MIDLANDS
    BISHOPS OF BROMYARD
    1 THE BYPASS
    BROMYARD
    HEREFORDSHIRE
    ESSENTIALS SERVICE STATION
    BROOM WAY
    LEE - ON - SOLENT
    HAMPSHIRE
    LONG MARCH SERVICE STATION
    ADMIRALS WAY
    DAVENTRY
    NORTHAMPTONSHIRE
    TCS Great Central
    89 Hillmorton Road
    Rugby
    Warwickshire
    WITTON ROAD SERVICE STATION
    338-358 WITTON ROAD
    BIRMINGHAM
    WEST MIDLANDS
    TCS Worcester Road
    141/149 Worcester Road
    Droitwich
    TCS Great Barr
    333/339 Birmingham Road
    Great Barr
    Birmingham
    West Midlands
    BELTON ROAD SERVICE STATION
    53 BELTON ROAD
    LOUGHBOROUGH
    LEICESTERSHIRE
    TCS Ayebridges
    171 Thorpe Lea Road
    Egham
    Surrey
    TCS Chobham
    Station Road
    Chobham
    Surrey
    TCS Lane End
    94 Melton Road
    Tollerton
    Nottingham
    Nottinghamshire
    TCS Isleworth
    403/405 Twickenham Road
    Isleworth
    Middlesex
    KISLINGBURY SERVICE STATION
    WEEDON ROAD
    KISLINGBURY
    NORTHAMPTON
    NORTHAMPTONSHIRE
    TCS Richmond
    22/24 Popham Gardens
    Lower Richmond Road
    Richmond
    Surrey
    TCS Harvey Road
    Harvey Road
    Derby
    Derbyshire
    TCS West Drayton
    Harmondsworth Road / Holloway Lane
    West Drayton
    Middlesex
    TCS Fleet
    Cove Road
    Fleet
    Farnborough
    Hampshire
    TCS Melksham
    Semington Road
    Melksham
    Wiltshire
    TCS Christchurch
    71/75 Somerford Road
    Christchurch
    Dorset
    TCS Broughton
    Childs Way
    Broughton
    Milton Keynes
    Buckinghamshire
    TCS Wokingham
    70 Finchampstead Road
    Wokingham
    Berkshire
    TCS Hemingford
    London Road
    Hemingford
    St Ives
    Cambridgeshire
    TCS Towcester Road
    Towcester Road
    Far Cotton
    Northamptonshire
    TCS Bedworth
    Newtown Road
    Bedworth
    Nuneaton
    Warwickshire
    TCS Hindhead
    Portsmouth Road
    Hindhead
    Surrey
    TCS Acton Park
    213/217 The Vale
    Acton
    Greater London
    TCS Gold Street
    Gold Street
    Wellingborough
    Northamptonshire
    TCS Compton
    Bridgenorth Road
    Wolverhampton
    West Midlands
    TCS Roughley
    81/85 Slade Road
    Sutton Coldfield
    Birmingham
    West Midlands
    TCS Sellers Wood
    Camberley Road
    Bulwell
    Nottingham
    Nottinghamshire
    DYSART WAY SERVICE STATION
    DYSART WAY
    LEICESTER
    LEICESTERSHIRE
    TCS Ashford
    102 Fordbridge Road
    Ashford
    Surrey
    TCS Farnborough
    22 Farnborough Road
    Farnborough
    Hampshire
    TCS Four Marks
    57 Winchester Road
    Four Marks
    Alton
    Hampshire
    TCS Houghton Green
    7 The Green
    Houghton Regis
    Dunstable
    Bedfordshire
    TCS Knaphill
    23 High Street
    Knaphill
    Woking
    Surrey
    TCS Blackhorse
    174/176 Sheen Road
    Richmond
    Surrey
    TCS Witney
    Welch Way
    Witney
    Oxfordshire
    TCS Bracknell
    78/82 Binfield Road
    Bracknell
    Berkshire
    TCS Hungerford
    1 Bath Road
    Hungerford
    Berkshire
    TCS Princes Risborough
    Lower Ickfield Way
    Longwick
    Prices Risborough
    Buckinghamshire
    TCS Kingston
    187/201 London Road
    Kingston-Upon-Thames
    Surrey
    TCS Swindon
    Mead Way
    Swindon
    Wiltshire
    TCS Old Woking
    65 High Street
    Old Woking
    Surrey
    TCS Durham Road
    Durham Road
    Sunderland
    Tyne and Wear
    TCS Thompson Road
    Thompson Road
    Southwick
    Sunderland
    Tyne and Wear
    TCS Clock
    Chilworth Roundabout
    Chilworth
    Southampton
    Hampshire
    TCS Minster
    102/104 Leigh Road
    Wimbourne
    Dorset
    TCS Newmarket
    220/22 High Street
    Newmarket
    Suffolk
    TCS Old Park
    Odiham Road
    Upper Hale
    Farnham
    Surrey
    TCS Cowley
    44/48 Garsington Road
    Cowley
    Oxford
    Oxfordshire
    DARLINGTON ROAD GARAGE
    DARLINGTON ROAD
    RICHMOND
    NORTH YORKSHIRE
    WINSLOW SELF SERVICE STATION
    HIGH STREET
    WINSLOW
    BUCKINGHAM
    BUCKINGHAMSHIRE
    LOWER LANE SUPERSTOP
    BERRY HILL
    COLEFORD
    GLOUCESTER
    GLOUCESTERSHIRE
    HEANOR ROAD SERVICE STATION
    HEANOR ROAD
    HEANOR
    DERBYSHIRE
    MAPLE LEAF GARAGE
    BRAUNSTON ROAD
    DAVENTRY
    NORTHAMPTONSHIRE
    TCS Falkland
    170 Andover Road
    Wash Common
    Newbury
    Berkshire
    TCS Leeming Lane
    43/45 Leeming Lane South
    Mansfield Woodhouse
    Nottinghamshire
    HERSHAM SERVICE STATION
    MOLESEY ROAD
    HERSHAM
    WALTON ON THAMES
    SURREY
    ASHGATE SERVICE STATION
    108 ASHGATE ROAD
    ASHGATE
    CHESTERFIELD
    DERBYSHIRE
    ALVERSTOKE SERVICE STATION
    PRIVETT ROAD
    ALVERSTOKE
    GOSPORT
    HAMPSHIRE
    BOTLEY SERVICE STATION
    STATION HILL
    CURDRIDGE
    NR SOUTHAMPTON
    HAMPSHIRE
    MEON HUT SERVICE STATION
    MEON HUT CROSSROADS
    WEST MEON
    PETERSFIELD
    HAMPSHIRE
    TCS Tower
    Oxford Road
    Stokenchurch
    Buckinghamshire
    BARNWOOD SUPER STOP
    109 BARNWOOD ROAD
    GLOUCESTER
    GLOUCESTERSHIRE
    DUDBRIDGE GARAGE
    DUDBRIDGE ROAD
    DUDBRIDGE
    STROUD
    GLOUCESTERSHIRE
    RESEARCH GARAGE
    LONDON ROAD
    HINCKLEY
    LEICESTERSHIRE
    LUTTERWORTH FORD
    LEICESTER ROAD
    LUTTERWORTH
    LEICESTERSHIRE
    BAKEWELL MOTORS
    HADDON ROAD
    BAKEWELL
    DERBYSHIRE
    TCS Matlock Green
    Matlock Green
    Matlock
    Derbyshire
    ALLDAYS - PASSFIELD AVENUE (CO-OP)
    MONKS BROOK SERVICE STATION
    147 - 149 PASSFIELD AVENUE
    EASTLEIGH
    HAMPSHIRE
    TCS Gloster Road
    Hucclecote Road
    Hucclecote
    Gloucester
    Gloucestershire
    MOUNT PLEASANT SERVICE STATION
    LONDON ROAD
    BUCKINGHAM
    BUCKINGHAMSHIRE
    TCS Milton Keynes
    Watling Street
    Little Brickhill
    Milton Keynes
    Bedfordshire
    TCS Raven
    372 Goldhawk Road
    Hammersmith
    Greater London
    TCS Marston Mortaine
    A421/Beancroft Road
    Marston Moretaine
    Bedfordshire
    TCS Barton Seagrave
    151 Barton Road
    Barton Seagrave
    Kettering
    Northamptonshire
    TCS Moulton
    Kettering Road
    Moulton
    Northamptonshire
    TCS Grovebury
    Leighton Road
    Billington
    Leighton Buzzard
    Bedfordshire
    TCS Slough East
    85 London Road
    Slough
    Berkshire
    MONMOUTH MWSA NORTH
    A40 NORTH SIDE
    DINGESTOW
    MONMOUTH
    GWENT
    MONMOUTH MWSA SOUTH
    A40 SOUTH SIDE
    DINGESTOW
    MONMOUTH
    GWENT
    TCS Boxtrees
    Stratford Road
    Hockley Heath
    Solihull
    West Midlands
    TCS Hinckley Road
    Hinckley Road
    Nuneaton
    Warwickshire
    BRISTOL STREET SERVICE STATION
    BRISTOL STREET
    BIRMINGHAM
    WEST MIDLANDS
    TCS Fairway
    Uttoxeter Road
    Mickleover
    Derbyshire
    TCS Larklands
    Nottingham Road
    Ilkeston
    Derbyshire
    TCS Winthorpe
    A46/A17 Winthorpe Roundabout
    Winthorpe
    Newark
    Nottinghamshire
    TCS Victoria
    320 Huntingdon Street
    Nottingham
    Nottinghamshire
    TCS New York
    New York Road
    Shiremoor
    Tyne and Wear
    TCS Godmanchester
    Cardinal Way
    Godmanchester
    Huntingdon
    Cambridgeshire
    TCS Appleby Magna
    Burton Road
    Acresford
    Swadlincote
    Derbyshire
    TCS Tove
    Watling Street
    Towcester
    Northamptonshire
    DURHAM MOTORWAY SERVICE AREA
    TURSDALE ROAD
    DURHAM
    COUNTY DURHAM
    TCS Awsworth
    Gin Close Way
    Awsworth
    Nottingham
    Nottinghamshire
    BINCHESTER SERVICE STATION
    BINCHESTER
    BISHOP AUCKLAND
    COUNTY DURHAM
    TCS Villa
    Leadgate Road
    Consett
    Durham
    TCS Peggy Bedford
    400 Bath Road (A4)
    Longford
    Middlesex
    TCS Leigh
    153 Narborough Road
    Leicester
    Leicestershire
    G NICHOLSON (ENGINEERS)
    BLUE HOUSE LANE
    WASHINGTON
    TYNE & WEAR
    SNIPPERSGATE FILLING STATION
    SOUTH HETTON ROAD
    HOUGHTON LE SPRING
    TYNE & WEAR
    TUXFORD ROAD GARAGE
    TUXFORD ROAD
    BOUGHTON
    NEWARK
    NOTTINGHAMSHIRE
    WITNEY ROAD GARAGE
    SPORTI SUZUKI
    WITNEY ROAD
    WITNEY
    OXFORDSHIRE
    BURNMOOR FILLING STATION
    BURNMOOR
    HOUGHTON LE SPRING
    TYNE & WEAR
    WHARF FARM SERVICE STATION
    COVENTRY ROAD
    HINCKLEY
    LEICESTERSHIRE
    EDENS LAWN SERVICE STATION
    HALTWHISTLE
    NORTHUMBERLAND
    STEVENSON OF OXBRIDGE LIMITED
    87 - 91 OXBRIDGE LANE
    STOCKTON ON TEES
    CLEVELAND
    KNIGHTON SELF SERVE
    445-449 WELFORD ROAD
    LEICESTER
    LEICESTERSHIRE
    CENTRAL AVENUE SERVICE STATION
    CENTRAL AVENUE
    NUNEATON
    WARWICKSHIRE
    VICTORIA ROAD SERVICE STATION
    21 - 23 VICTORIA ROAD
    RICHMOND
    NORTH YORKSHIRE
    J E HAMMOND & SON
    KELVIN WAY
    WEST BROMWICH
    WEST MIDLANDS
    CARRVILLE SERVICE STATION
    HADRIAN ROAD
    WALLSEND
    TYNE & WEAR
    FORDINGBRIDGE SERVICE STATION
    SOUTHAMPTON ROAD
    FORDINGBRIDGE
    HAMPSHIRE
    DAFF-Y-NANT SSERVICE STATION
    A40 SOUTHBOUND
    WHITCHURCH
    ROSS-ON-WYE
    HEREFORDSHIRE
    SPRING HILL SERVICE STATION
    166 - 176 SPRING HILL
    HOCKLEY
    BIRMINGHAM
    WEST MIDLANDS
    EASTFIELD SERVICE STATION
    139 EASTFIELD SIDE
    SUTTON IN ASHFIELD
    NOTTINGHAMSHIRE
    SUMMER LANE SERVICE STATION
    90 SUMMER LANE
    BIRMINGHAM
    WEST MIDLANDS
    KINGS OF SEDGLEY
    318 WOLVERHAMPTON ROAD
    SEDGLEY
    DUDLEY
    WEST MIDLANDS
    CARRINGTON SERVICE STATION
    HUCKNALL ROAD
    CARRINGTON
    NOTTINGHAM
    NOTTINGHAMSHIRE
    SHERWOOD RISE SERVICE STATION
    SHERWOOD RISE
    NOTTINGHAM
    NOTTINGHAMSHIRE
    SHEPSHED SERVICE STATION
    ASHBY ROAD
    SHEPSHED
    LEICESTERSHIRE
    EREWASH VALLEY SERVICE STATION
    50 NOTTINGHAM ROAD
    SPONDON
    DERBY
    DERBYSHIRE
    FOLESHILL ROAD SERVICE STATION
    650 - 654 FOLESHILL ROAD
    COVENTRY
    WARWICKSHIRE
    JUNCTION SERVICE STATION
    WILSTHORPE ROAD
    LONG EATON
    NOTTINGHAMSHIRE
    SEDGEMOOR MWSA
    M5 JUNCTION 22-22 SOUTHBOUND
    ROOKSBRIDGE
    AXBRIDGE
    SOMERSET
    BROOKHOUSE SERVICE STATION
    59 ECCLESHALL ROAD
    STAFFORD
    STAFFORDSHIRE
    KEMPSTON SERVICE STATION
    WOBURN ROAD
    KEMPSTON
    BEDFORDSHIRE
    BRIDGE ROAD SERVICE STATION
    16 BRIDGE ROAD
    COVE
    FARNBOROUGH
    HAMPSHIRE
    ALBANY SERVICE STATION
    LONDON ROAD
    HOOK
    HAMPSHIRE
    ST NEOTS SERVICE STATION
    66 - 76 CAMBRIDGE STREET
    ST NEOTS
    CAMBRIDGESHIRE
    ACADEMY SERVICE STATION
    103 YORK TOWN ROAD
    SANDHURST
    SURREY
    BLACKWATER SERVICE STATION
    86 LONDON ROAD
    BLACKWATER
    CAMBERLEY
    SURREY
    RUNNEYMEDE SERVICE STATION
    38 - 45 THE AVENUE
    EGHAM
    SURREY
    SPAR HASLAND
    MANSFIELD ROAD
    HASLAND
    CHESTERFIELD
    DERBYSHIRE
    PIRTON CORNER SERVICE STATION
    CHELTENHAM ROAD EAST
    CHURCHDOWN
    GLOUCESTER
    GLOUCESTERSHIRE
    CROSS SERVICE STATION
    4 SWANSEA ROAD
    PENLLERGAER
    SWANSEA
    WEST GLAMORGAN
    CHURCHILL SERVICE STATION
    113-117 BOURNEMOUTH ROAD
    POOLE
    DORSET
    DERWENT SERVICE STATION
    DERWENTHAUGH ROAD
    SWALWELL
    NEWCASTLE UPON TYNE
    TYNE & WEAR
    TCS Colliery
    HAMSTEAD ROAD
    GREAT BARR
    BIRMINGHAM
    WEST MIDLANDS
    PENRHOS SERVICE STATION
    NANT GARW HILL
    CARDIFF
    MID GLAMORGAN
    CARDIFF BAY SERVICE STATION
    235 CORPORATION ROAD
    GRANGETOWN
    CARDIFF
    SOUTH GLAMORGAN
    TCS Sports Centre
    360 HILL LANE
    SOUTHAMPTON
    HAMPSHIRE
    TCS Aldershot
    PARK GARAGE
    400 HIGH STREET
    ALDERSHOT
    HAMPSHIRE
    CLOCKMILL ROAD SERVICE STATION
    CLOCKMILL ROAD
    GATESHEAD
    NEWCASTLE UPON TYNE
    TYNE & WEAR
    STAINES SERVICE STATION
    CHERTSEY LANE
    STAINES
    MIDDLESEX
    THAMES VALLEY SERVICE STATION
    GEORGE STREET
    CAVERSHAM
    BERKSHIRE
    LENT RISE SERVICE STATION
    LENT RISE ROAD
    BURNHAM
    BUCKINGHAMSHIRE
    PLAWSWORTH SERVICE STATION
    A167 NORTHBOUND
    PLAWSWORTH
    CHESTER LE STREET
    COUNTY DURHAM
    WASHINGTON SERVICE STATION
    HEWORTH ROAD
    WASHINGTON
    TYNE & WEAR
    WINDSOR SERVICE STATION
    191-195 DEDWORTH ROAD
    WINDSOR
    BERKSHIRE
    COAST ROAD SERVICE STATION
    COAST ROAD
    BLACKHALL
    PETERLEE
    COUNTY DURHAM
    SEDGEFIELD SERVICE STATION
    A177 SEDGEFIELD
    STOCKTON ON TEES
    CLEVELAND
    PARADE SERVICE STATION
    THE PARADE
    BOURNE END
    BUCKINGHAMSHIRE
    TOWN HALL SERVICE STATION
    CROSSGATES
    SOUTH SHIELDS
    TYNE & WEAR
    STONNALL SERVICE STATION
    CHESTER ROAD
    STONNALL
    WALSALL
    WEST MIDLANDS
    BALSALL COMMON SERVICE STATION
    KENILWORTH ROAD
    BALSALL COMMON
    COVENTRY
    WARWICKSHIRE
    SOUTHWELL SERVICE STATION
    SOUTHWELL ROAD WEST
    MANSFIELD
    NOTTINGHAMSHIRE
    CARLTON SQUARE SERVICE STATION
    CARLTON HILL
    CARLTON
    NOTTINGHAM
    NOTTINGHAMSHIRE
    TOTON LANE SERVICE STATION
    181 TOTON LANE
    STAPLEFORD
    NOTTINGHAMSHIRE
    LONDON ROAD SERVICE STATION
    LONDON ROAD
    NEW BALDERTON
    NEWARK
    NOTTINGHAMSHIRE
    MARLBROOK SERVICE STATION
    491 BIRMINGHAM ROAD
    MARLBROOK
    BROMSGROVE
    WORCESTERSHIRE
    STOURPORT SERVICE STATION
    WORCESTER ROAD
    STOURPORT ON SEVERN
    WORCESTERSHIRE
    WORCESTER SERVICE STATION
    241 - 243 HENWICK ROAD
    WORCESTER
    WORCESTERSHIRE
    REDWOOD SERVICE STATION
    JARROW ROAD
    TYNE DOCK
    SOUTH SHIELDS
    TYNE & WEAR
    COCKTON HILL SERVICE STATION
    COCKTON HILL ROAD
    BISHOPS AUCKLAND
    COUNTY DURHAM
    STATION DORRIDGE SERVICE STATION
    GRANGE ROAD
    DORRIDGE
    SOLIHULL
    WEST MIDLANDS
    CROSSROADS SERVICE STATION
    2 SOUTHWELL ROAD WEST
    MANSFIELD
    NOTTINGHAMSHIRE
    TUDOR LODGE SERVICE STATION
    MARTON ROAD
    MIDDLESBOROUGH
    CLEVELAND
    CORONATION SERVICE STATION
    245 ACKLAM ROAD
    ACKLAM
    MIDDLESBROUGH
    CLEVELAND
    BRIDGE CENTRE SERVICE STATION
    HOLBROOK ROAD
    PORTSMOUTH
    HAMPSHIRE
    COACH HOUSE SERVICE STATION
    40 - 44 DRAGON STREET
    PETERSFIELD
    HAMPSHIRE
    PRIORY SERVICE STATION
    WINCHESTER ROAD
    BISHOP WALTHAM
    SOUTHAMPTON
    HAMPSHIRE
    BADDESLEY SERVICE STATION
    54 BOTLEY ROAD
    NORTH BADDESLEY
    SOUTHAMPTON
    HAMPSHIRE
    PORTWAY SERVICE STATION
    H5 PORTWAY
    BRADWELL COMMON
    MILTON KEYNES
    BUCKINGHAMSHIRE
    MALTHURST MORPETH
    STANLEY TERRACE
    MORPETH
    NORTHUMBERLAND
    MALTHURST VIGO LANE
    DURHAM ROAD
    BIRTLEY
    CHESTER LE STREET
    COUNTY DURHAM
    MALTHURST STONEBRIDGE
    A690
    NEVILLES CROSS BANK
    DURHAM
    COUNTY DURHAM
    MALTHURST EYNSHAM
    A40
    EYNSHAM
    WITNEY
    OXFORDSHIRE
    KINGSMEAD SERVICE STATION
    FARNBOROUGH ROAD
    FARNBOROUGH
    HAMPSHIRE
    ALBION ROAD SERVICE STATION
    ALBION ROAD
    PONTYPOOL
    GWENT
    FESTIVAL SERVICE STATION
    BYPASS ROAD
    EBBW VALE
    GWENT
    WEST END SERVICE STATION
    CHURCH STREET
    BRECON
    POWYS
    JUDD'S GARAGE
    A44
    WOODLEYS
    WOODSTOCK
    OXFORDSHIRE
    HENLEY ROAD SERVICE STATION
    HENLEY ROAD
    COURT HOUSE GREEN
    COVENTRY
    WEST MIDLANDS
    SQUARE & COMPASS FILLING STATION
    SQUARE & COMPASS
    MATHRY
    HAVERFORDWEST
    DYFED
    MERIDIAN SERVICE STATION
    GLOUCESTER ROAD
    NEWENT
    GLOUCESTERSHIRE
    MG GARAGES GREET
    372 WARWICK ROAD
    GREET
    BIRMINGHAM
    WEST MIDLANDS
    MALTHURST ST RICHARDS
    NARBOROUGH ROAD
    LEICESTER
    LEICESTERSHIRE
    MALTHURST EGERTON PARK
    LEICESTER ROAD
    MELTON MOWBRAY
    LEICESTERSHIRE
    MALTHURST EAST LANE
    WESTDALE LANE EAST
    GELDING
    NOTTINGHAM
    NOTTINGHAMSHIRE
    MALTHURST NUTHALL ROAD
    NUTHALL ROAD
    APSLEY
    NOTTINGHAM
    NOTTINGHAMSHIRE
    MALTHURST MELTON ROAD
    MELTON ROAD
    WESTBRIDGFORD
    NOTTINGHAM
    NOTTINGHAMSHIRE
    MALTHURST PEVERIL
    SHEFFIELD ROAD
    CHESTERFIELD
    DERBYSHIRE
    FENTON SERVICE STATION
    400 KING STREET
    FENTON
    STOKE ON TRENT
    STAFFORDSHIRE
    TURGIS GREEN SERVICE STATION
    READING ROAD
    TURGIS GREEN
    BASINGSTOKE
    HAMPSHIRE
    BUSBY STOOP GARAGE
    BUSBY STOOP
    THIRSK
    NORTH YORKSHIRE
    DEVIZES SERVICE STATION
    THE NURSERY
    NORTHGATE STREET
    DEVIZES
    WILTSHIRE
    CONGRESBURY SERVICE STATION
    WESTON ROAD
    CONGRESBURY
    AVON
    WESTBURY SERVICE STATION
    39 WARMINSTER ROAD
    WESTBURY
    WILTSHIRE
    HOLLYBUSH SERVICE STATION
    THORNABY ROAD
    THORNABY
    STOCKTON ON TEES
    CLEVELAND
    ST CUTHBERTS WAY SERVICE STATION
    ST CUTHBERTS WAY
    NEWTON AYCLIFFE
    COUNTY DURHAM
    GRANGE ROAD SERVICE STATION
    68-70 GRANGE ROAD
    DARLINGTON
    COUNTY DURHAM
    No 1 FILLING STATION LTD
    22 - 23 PALLION ROAD
    SUNDERLAND
    TYNE & WEAR
    ST LEONARDS SERVICE STATION
    LONDON ROAD
    GRANTHAM
    LINCOLNSHIRE
    HIGH STREET SERVICE STATION
    HIGH STREET
    CLAY CROSS
    CHESTERFIELD
    DERBYSHIRE
    GLOUCESTER ROAD SERVICE STATION
    410 - 422 GLOUCESTER ROAD
    HORFIELD
    BRISTOL
    AVON
    WALKERS GARAGE
    136 BURTON ROAD
    CARLTON
    NOTTINGHAM
    NOTTINGHAMSHIRE
    WETLEY ROCKS FILLING STATION
    679 CHEADLE ROAD
    WHETLEY ROCKS
    STOKE ON TRENT
    STAFFORDSHIRE
    232 BATH ROAD
    SLOUGH
    BERKSHIRE
    CHELTENHAM SERVICE STATION
    BOUNCERS LANE
    PRESTBURY
    CHELTENHAM
    GLOUCESTERSHIRE
    MOULSFORD SERVICE STATION
    READING ROAD
    MOULSFORD
    WALLINGFORD
    OXFORDSHIRE
    SELSTON MOTOR SERVICES
    129 NOTTINGHAM ROAD
    SELSTON
    NOTTINGHAMSHIRE
    GLENFIELD ROAD SERVICE STATION
    50 GLENFIELD ROAD
    LEICESTER
    LEICESTERSHIRE
    WOODHAM SERVICES
    BURNHILL WAY
    NEWTON AYCLIFFE
    COUNTY DURHAM
    SAFFRON LANE SERVICE STATION
    SAFFRON LANE
    AYLESTONE PARK
    LEICESTER
    LEICESTERSHIRE
    TILEHURST SERVICE STATION
    SCHOOLROAD
    TILEHURST
    READING
    BERKSHIRE
    TEAN SERVICE STATION
    DRAYCOTT ROAD
    UPPER TEAN
    STOKE ON TRENT
    STAFFORDSHIRE
    HAYES SERVICE STATION
    132 COLDHARBOUR LANE
    HAYES
    MIDDLESEX
    BLACK CAT SERVICE STATION
    GREAT NORTH ROAD
    CHAWSTON
    BEDFORD
    BEDFORDSHIRE
    RUSHDEN SERVICE STATION
    181 WELLINGBOROUGH ROAD
    RUSHDEN
    NORTHAMPTONSHIRE
    LOLWORTH SERVICE STATION
    HUNTINGDON ROAD
    LOLWORTH
    CAMBRIDGESHIRE
    ACTON VALE SERVICE STATION
    30 THE VALE
    ACTON
    LONDON
    SEATON BURN SERVICE STATION
    FISHER LANE
    SEATON BURN
    NEWCASTLE UPON TYNE
    TYNE & WEAR
    ANNFIELD PLAIN SERVICE STATION
    MORRISON ROAD
    ANNFIELD PLAIN
    STANLEY
    COUNTY DURHAM
    HUTHWAITE SERVICE STATION
    HUTHWAITE ROAD
    SUTTON - IN - ASHFIELD
    NOTTINGHAMSHIRE
    HARTSHAY HILL SERVICE STATION
    HARTSHAY HILL
    RIPLEY
    DERBYSHIRE
    CONNAUGHT SERVICE STATION
    BAGSHOT ROAD
    BROOKWOOD
    WOKING
    SURREY
    FOLEY SERVICE STATION
    1 BEACON HILL
    ALRDRIDGE
    WALSALL
    WEST MIDLANDS
    FHSS (NORTHERN) LTD
    MORTON CRESCENT
    FENCEHOUSE
    COUNTY DURHAM
    DAVENTRY SERVICE STATION
    VICAR LANE
    DAVENTRY
    NORTHAMPTONSHIRE
    FULWOOD SERVICE STATION
    367 - 369 ALFRETON ROAD
    SUTTON IN ASHFIELD
    NOTTINGHAMSHIRE
    BURTON SERVICE STATION
    WELLINGTON ROAD
    BURTON ON TRENT
    STAFFORDSHIRE
    DERBY ROAD SERVICE STATION
    DERBY ROAD
    BURTON UPON TRENT
    STAFFORDSHIRE
    SWANWICK SERVICE STATION
    DERBY ROAD
    SWANWICK
    ALFRETON
    DERBYSHIRE
    KIDDERMINSTER SERVICE STATION
    WORCESTER ROAD
    HOODBROOK
    KIDDERMINSTER
    WORCESTERSHIRE
    RUGELEY SERVICE STATION
    MAIN ROAD
    BRERETON
    RUGELEY
    STAFFORDSHIRE
    NORTHGATE SERVICE STATION
    NORTHGATE
    ALDRIDGE
    WALSALL
    WEST MIDLANDS
    WOODSETTON SERVICE STATION
    SEDGELEY ROAD
    WOODSETTON
    DUDLEY
    WEST MIDLANDS
    BRIERLEY HILL SERVICE STATION
    BRETTEL LANE
    BRIERLEY LANE
    DUDLEY
    WEST MIDLANDS
    MALTHURST MILTON KEYNES
    H6 CHILDS WAY
    FISHERMEAD
    MILTON KEYNES
    BUCKINGHAMSHIRE
    MILLFIELDS SERVICE STATION
    3 - 5 MILLFIELDS ROAD
    BILSTON
    WOLVERHAMPTON
    WEST MIDLANDS
    193 ASTON LANE
    PERRY BARR
    BIRMINGHAM
    WEST MIDLANDS
    BIRMINGHAM ROAD SERVICE STATION
    BIRMINGHAM ROAD/DUDLEY ROAD
    WOLVERHAMPTON
    WEST MIDLANDS
    UPLANDS SERVICE STATION
    264 - 266 OXHILL ROAD
    HANDSWORTH
    BIRMINGHAM
    WEST MIDLANDS
    BROMSGROVE ROAD SERVICE STATION
    BROMSGROVE ROAD
    HALESOWEN
    WEST MIDLANDS
    ANNES PANTRY SERVICE STATION
    COVENTRY ROAD
    BICKENHILL
    SOLIHULL
    WEST MIDLANDS
    WASHWOOD HEATH SERVICE STATION
    288 WASHWOOD HEATH ROAD
    SALTLEY
    BIRMINGHAM
    WEST MIDLANDS
    SPARKHILL SERVICE STATION
    636 STRATFORD ROAD
    SPARKHILL
    BIRMINGHAM
    WEST MIDLANDS
    LANDMARK SERVICE STATION
    A45 LONDON ROAD
    DAVENTRY
    NORTHAMPTONSHIRE
    LANE HEAD SERVICE STATION
    HIGH ROAD
    LANE HEAD
    WILLENHALL
    WEST MIDLANDS
    CLUMBER SERVICE STATION
    SCOTSWOOD ROAD
    CRUDDAS PARK
    NEWCASTLE UPON TYNE
    TYNE & WEAR
    MILVERTON SERVICE STATION
    130 RUGBY ROAD
    LEAMINGTON SPA
    WARWICKSHIRE
    TIMBERLEY SERVICE STATION
    296 - 306 CHESTER ROAD
    CASTLE BROMWICH
    BIRMINGHAM
    WEST MIDLANDS
    PYPE HAYES SERVICE STATION
    912 KINGSBURY ROAD
    ERDINGTON
    BIRMINGHAM
    WEST MIDLANDS
    BRACEBRIDGE SERVICE STATION
    58 - 62 WALSALL ROAD
    SUTTON COLDFIELD
    WEST MIDLANDS
    WEATHEROAKS SERVICE STATION
    ALCESTER ROAD
    WYTHALL
    BIRMINGHAM
    WEST MIDLANDS
    SOUTHSIDE SERVICE STATION
    OYODEN WAY
    PETERLEE
    COUNTY DURHAM
    PARK ROAD SERVICE STATION
    PARK ROAD NORTH
    CHESTER - LE - STREET
    COUNTY DURHAM
    BOLTON ROAD SERVICE STATION
    SMALL HEATH HIGHWAY (A45)
    SMALL HEATH
    BIRMINGHAM
    WEST MIDLANDS
    BELLINI'S
    HEANOR ROAD
    ILKESTON
    DERBYSHIRE
    NIX SERVICE STATION
    FORTON ROAD
    NEWPORT
    SHROPSHIRE
    EYEMOUTH SERVICE STATION
    ACREDALE INDUSTRIAL ESTATE
    COLDINGHAM ROAD
    EYEMOUTH
    BERWICKSHIRE
    MIBSONS SERVICE STATION WHETSTONE
    16 CAMBRIDGE ROAD
    WHETSTONE
    LEICESTER
    LEICESTERSHIRE
    LITTLEWICK GREEN SERVICE STATION
    BATH ROAD
    LITTLEWICK GREEN
    MAIDENHEAD
    BERKSHIRE
    EASTLEIGH SERVICE STATION
    69-73 BISHOPSTOKE ROAD
    EASTLEIGH
    SOUTHAMPTON
    HAMPSHIRE
    RING ROAD SERVICE STATION
    OSMASTON PARK ROAD
    DERBY
    DERBYSHIRE
    ALTON SERVICE STATION
    ALTON ROAD
    UPPER FROYLE
    ALTON
    HAMPSHIRE
    BINLEY ROAD SERVICE STATION
    BINLEY ROAD
    COVENTRY
    WARWICKSHIRE
    MRH BURTON
    116 ASHBY ROAD
    WINSHILL
    BURTON ON TRENT
    STAFFORDSHIRE
    MRH WOODHOUSE
    WOODHOUSE WAY
    NUTHALL
    NOTTINGHAM
    NOTTINGHAMSHIRE
    BUCKS HORN OAK SERVICE STATION
    MAIN ROAD
    FARNHAM
    HAMPSHIRE
    MRH MAID MARION
    MANSFIELD ROAD
    REDGILL
    NOTTIINGHAM
    NOTTINGHAMSHIRE
    COLSTERWORTH SERVICE STATION
    A1 NORTH
    COLSTERWORTH
    GRANTHAM
    LINCOLNSHIRE
    AUTOSTOP SERVICE STATION
    54 LAWFORD ROAD
    RUGBY
    WARWICKSHIRE
    FRADLEY SERVICE AREA (NORTHBOUND)
    RYKNIELD STREET
    FRADLEY
    LICHFIELD
    STAFFORDSHIRE
    FRADLEY SERVICE AREA (SOUTHBOUND)
    RYKNIELD STREET
    FRADLEY
    LICHFIELD
    STAFFORDSHIRE
    MCCOLL PETROL STATION
    78 GLASCOTE ROAD
    TAMWORTH
    STAFFORDSHIRE
    WESTWAY PETROL FILLING STATION
    CASTLE LANE WEST
    BOURNEMOUTH
    DORSET
    MALTHURST OLLERTON
    OLD OLLERTON ROAD
    OLLERTON
    NOTTINGHAMSHIRE
    LION GARAGE
    BRIDGE STREET
    BELPER
    DERBYSHIRE
    DARLASTON SERVICE STATION
    OWEN ROAD
    WILLENHALL
    WEST MIDLANDS
    FRIMLEY GREEN SERVICE STATION
    257 - 259 FRIMLEY GREEN ROAD
    CAMBERLEY
    SURREY
    WOOTTON BASSETT PETROL STATION
    94 HIGH STREET
    WOOTTON BASSETT
    WILTSHIRE
    HINDMARCH GARAGE
    UFFINGTON ROAD
    STAMFORD
    LINCOLNSHIRE
    EMPIRE GARAGE
    ALFORD ROAD
    MABLETHORPE
    LINCOLNSHIRE
    CLIFTON SERVICE STATION
    5 CHURCH STREET
    NORTON
    MALTON
    NORTH YORKSHIRE
    FYLINGDALES SERVICE STATION
    FYLINGDALES
    WHITBY
    NORTH YORKSHIRE
    FERRIBY SERVICE STATION
    A63 WESTBOUND
    NORTH FERRIBY
    NORTH HUMBERSIDE
    STATION GARAGE
    MIDDLE STREET SOUTH
    DRIFFIELD
    EAST YORKSHIRE
    GILES BROS LIMITED
    2 - 4 HOLLYM ROAD
    WITHERNSEA
    EAST YORKSHIRE
    SPRINGFIELD GARAGE
    OAKWORTH ROAD
    KEIGHLEY
    WEST YORKSHIRE
    MALTHURST GLEADLESS
    RIDGEWAY ROAD
    SHEFFIELD
    SOUTH YORKSHIRE
    NORMANTON SERVICE STATION
    CASTLEFORD ROAD
    NORMANTON
    WEST YORKSHIRE
    F TROOP & SON
    THE GARAGE
    LINCOLN ROAD
    LEADENHAM
    LINCOLNSHIRE
    DEARNE VALLEY GARAGE
    WAKEFIELD ROAD
    SCISSETT
    HUDDERSFIELD
    WEST YORKSHIRE
    GRANGE SERVICE STATION
    DENBY DALE ROAD
    DURKAR
    WAKEFIELD
    WEST YORKSHIRE
    SAVILE ROAD SERVICE STATION
    SAVILE ROAD
    CASTLEFORD
    WEST YORKSHIRE
    PUDSEY ROAD SERVICE STATION
    174 PUDSEY ROAD
    BRAMLEY
    LEEDS
    WEST YORKSHIRE
    RIVERSIDE SERVICE STATION
    431 KIRKSTALL ROAD
    LEEDS
    WEST YORKSHIRE
    NOWELL FILLING STATION
    HAREHILLS LANE
    LEEDS
    WEST YORKSHIRE
    REDBECK SERVICE STATION
    DONCASTER ROAD
    CROFTON
    WAKEFIELD
    WEST YORKSHIRE
    SOUTH ANSTON SERVICE STATION
    WORKSOP ROAD
    SOUTH ANSTON
    SHEFFIELD
    SOUTH YORKSHIRE
    TCS Leeds Road
    32 Leeds Road
    Tadcaster
    North Yorkshire
    TCS Apollo
    791/811 Huddersfield Road
    Ravensthorpe
    Dewsbury
    West Yorkshire
    BRAMPTON SERVICE STATION
    561 CHATSWORTH ROAD
    BRAMPTON
    CHESTERFIELD
    DERBYSHIRE
    TCS Wetherby
    North Street
    Wetherby
    West Yorkshire
    TCS Peterborough
    Whittlesey Road
    Stanground
    Peterborough
    Cambridgeshire
    TCS Brough
    Welton Road
    Brough
    Hull
    Humberside
    TCS Tong Road
    147 Tong Road
    Leeds
    West Yorkshire
    MIDWAY GARAGE & CAFÉ
    BOSTON ROAD
    BOSTON
    LINCOLNSHIRE
    PARSONS CROSS FILLING STATION
    WORDSWORTH AVENUE
    SHEFFIELD
    SOUTH YORKSHIRE
    MIDDLETON SERVICE STATION
    MAIN STREET
    PICKERING
    NORTH YORKSHIRE
    TCS Broadlands
    Yarmouth Road
    Witton
    Norwich
    Norfolk
    TCS Kings Lynn
    Junction of A17/A47
    West Lynn
    Kings Lynn
    Norfolk
    TCS Rosedale
    Dale Road
    Rawmarsh
    Rotherham
    South Yorkshire
    TCS Steering Wheel
    Bawtry Road
    Hellaby
    Rotherham
    South Yorkshire
    MOORGATE SERVICE STATION
    MOORGATE
    RETFORD
    NOTTINGHAMSHIRE
    TCS London Bridge
    Tadcaster Road
    York
    North Yorkshire
    TCS Thorpe on the Hill
    A46/A15 Newark Intersection
    Lincoln Relief Road
    Thorpe on the Hill
    Lincolnshire
    TCS Holdingham
    Junction A15/A17
    Holdingham Roundabout
    Sleaford
    Lincolnshire
    TCS Dukeries
    St Annes Drive
    Mansfield Drive
    Worksop
    Nottinghamshire
    TCS Midway
    Topcliffe Road
    Topcliffe
    Thirsk
    North Yorkshire
    GIBBETT NOOK SERVICE STATION
    TUMBY ROAD
    LINCOLN
    LINCOLNSHIRE
    WINNING POST SERVICE STATION
    CARHOLME ROAD
    LINCOLN
    LINCOLNSHIRE
    TCS Wisbech
    North Walton Highway
    A47 Wisbech By-Pass
    Wisbech
    Cambridgeshire
    TCS Thickthorn
    Norwich Road
    Heathersett
    Norwich
    Norfolk
    TCS Carlisle Street
    Carlisle Street East
    Sheffield
    South Yorkshire
    TCS Low Moor
    Cleckheaton Road
    Low Moor
    Bradford
    West Yorkshire
    TCS Aberford Road
    56 Aberford Road
    Oulton
    Leeds
    West Yorkshire
    CORNER GARAGE
    MARKET PLACE
    BAWTRY
    DONCASTER
    SOUTH YORKSHIRE
    STALHAM ENGINEERING
    THE GREEN
    STALHAM
    NORWICH
    NORFOLK
    BARRIECARS SERVICE STATION
    HIGH STREET
    DUNSVILLE
    DONCASTER
    SOUTH YORKSHIRE
    BLUE STONE SERVICES
    STALLINGBOROUGH ROAD
    IMMINGHAM
    SOUTH HUMBERSIDE
    MORLEYS SERVICE STATION
    196 WITHAM ROAD
    WOODHALL SPA
    LINCOLNSHIRE
    T D MOTORS
    77 STATION ROAD
    SKEGNESS
    LINCOLNSHIRE
    MAYBURY VILLAGE SERVICE STATION
    MAYBURY ROAD
    HULL
    EAST YORKSHIRE
    BOSTON ROAD SERVICE STATION
    BOSTON ROAD
    HORNCASTLE
    LINCOLNSHIRE
    CATHILL SERVICES
    DONCASTER ROAD
    DARFIELD
    SHEFFIELD
    SOUTH YORKSHIRE
    SOUTHCOATES SERVICE STATION
    SOUTHCOATES LANE
    HULL
    EAST YORKSHIRE
    NORFOLK PARK SERVICE STATION
    EAST BANK ROAD
    SHEFFIELD
    SOUTH YORKSHIRE
    A16 GARAGE
    GRIMSBY ROAD
    LOUTH
    LINCOLNSHIRE
    PENISTONE ROAD SERVICE STATION
    PENISTONE ROAD
    SHEFFIELD
    SOUTH YORKSHIRE
    BEVERLEY SERVICE STATION
    HOLME CHURCH LANE
    BEVERLEY
    NORTH HUMBERSIDE
    SOUTH CAVE SERVICE STATION
    BROUGH ROAD
    SOUTH CAVE
    EAST YORKSHIRE
    SUTTON SERVICE STATION
    ROBSON WAY
    HULL
    EAST YORKSHIRE
    SOUTH BANK SERVICES
    FERRIBY ROAD
    BARTON UPON HUMBER
    SOUTH HUMBERSIDE
    SNAITH HALL FILLING STATION
    PONTEFRACT ROAD
    GOOLE
    EAST YORKSHIRE
    CAENBY CORNER GARAGE
    CAENBY CORNER
    MARKET RASEN
    LINCOLNSHIRE
    BANKSIDE GARAGE
    WORTLEY ROAD
    ROTHERHAM
    SOUTH YORKSHIRE
    WHARNCLIFFE GARAGE
    SUMMER LANE
    BARNSLEY
    SOUTH YORKSHIRE
    FOSTERS OF THRYBERGH
    DONCASTER ROAD
    THRYBERGH
    ROTHERHAM
    SOUTH YORKSHIRE
    POPPLETON GARAGE
    BOROUGHBRIDGE ROAD
    YORK
    NORTH YORKSHIRE
    PHOENIX FILLING STATION
    93 LISTERHILLS ROAD
    BRADFORD
    WEST YORKSHIRE
    LUXMORE SERVICES EASTBOUND
    A180 EASTBOUND
    HARBOROUGH
    IMMINGHAM
    SOUTH HUMBERSIDE
    LUXMORE SERVICES WESTBOUND
    A180 WESTBOUND
    HARBOROUGH
    IMMINGHAM
    SOUTH HUMBERSIDE
    GLINTON SERVICE STATION
    LINCOLN ROAD
    GLINTON
    PETERBOROUGH
    CAMBRIDGESHIRE
    SHAWCROSS SERVICE STATION
    LEEDS ROAD
    SHAWCROSS
    DEWSBURY
    WEST YORKSHIRE
    GLASSHOUGHTON SERVICE STATION
    FRONT STREET
    GLASSHOUGHTON
    CASTLEFORD
    WEST YORKSHIRE
    OTLEY ROAD SERVICE STATION
    OTLEY ROAD
    BAILDON
    SHIPLEY
    WEST YORKSHIRE
    ORCHARD SERVICE STATION
    BRADFORD ROAD
    BURLEY IN WHARFDALE
    BRADFORD
    WEST YORKSHIRE
    RAWDON SERVICE STATION
    APPERLEY LANE
    YEADON
    LEEDS
    WEST YORKSHIRE
    ROSEMOUNT SERVICE STATION
    ABERFORD ROAD
    STANLEY
    WAKEFIELD
    WEST YORKSHIRE
    ACKWORTH SERVICE STATION
    A638 WAKEFIELD ROAD
    ACKWORTH
    WAKEFIELD
    WEST YORKSHIRE
    BRETTON SERVICE STATION
    ROTHERHAM ROAD
    MONK BRETTON
    BARNSLEY
    SOUTH YORKSHIRE
    STUBLEY SERVICE STATION
    STUBLEY LANE
    DRONFIELD WOODHOUSE
    DRONFIELD
    DERBYSHIRE
    DENBROOK SERVICE STATION
    541 TONG STREET
    BRADFORD
    WEST YORKSHIRE
    CANLKOW SERVICE STATION
    CANKLOW ROUNFABOUT
    BRINSWORTH
    ROTHERHAM
    SOUTH YORKSHIRE
    SLEAFORD ROAD SERVICE STATION
    SLEAFORD ROAD
    BRACEBRIDGE HEATH
    LINCOLN
    LINCOLNSHIRE
    DONCASTER ROAD SERVICE STATION
    DONCASTER ROAD
    CONISBOROUGH
    DONCASTER
    SOUTH YORKSHIRE
    WHITE ROSE SERVICE STATION
    BAWTRY ROAD
    BRAMLEY
    ROTHERHAM
    SOUTH YORKSHIRE
    MALTBY SERVICE STATION
    ROTHERHAM ROAD
    MALTBY
    ROTHERHAM
    SOUTH YORKSHIRE
    LEVEN ROAD SERVICE STATION
    LEVEN ROAD
    CATWICK
    BEVERLEY
    EAST YORKSHIRE
    MALTHURST BILBOROUGH
    A64 EASTBOUND
    TADCASTER
    NORTH YORKSHIRE
    MARSH LANE FILLING STATION
    DRONFIELD ROAD
    SHEFFIELD
    SOUTH YORKSHIRE
    WEST CAVE SERVICE STATION
    A63 WESTBOUND
    NEWPORT
    BROUGH
    NORTH HUMBERSIDE
    WYTON BAR SERVICE STATION
    MAIN STREET
    HULL
    BILTON
    EAST YORKSHIRE
    HOLDERNESS SERVICE STATION
    HOLERNESS ROAD
    HULL
    EAST YORKSHIRE
    POCKLINGTON SERVICE STATION
    BARMBY ROAD
    POCKLINGTON
    YORK
    EAST YORKSHIRE
    WILLERBY & WILLERBY PARK SERVICE STAITONS
    BEVERLEY ROAD
    HULL
    WILLERBY
    EAST YORKSHIRE
    COTTINGHAM SERVICE STATION
    NORTHGATE
    HULL
    NORTH HUMBERSIDE
    DARNALL SERVICE STATION
    GREENLAND ROAD
    DARNALL
    SHEFFIELD
    SOUTH YORKSHIRE
    CHANTERLANDS SERVICE STATION
    247A CHANTERLANDS AVENUE
    HULL
    NORTH HUMBERSIDE
    BOOTHFERRY ROAD SERVICE STATION
    288 BOOTHFERRY ROAD
    HESSLE
    EAST YORKSHIRE
    HIGH STREET
    BOSTON
    LINCOLNSHIRE
    SHOWGROUND SERVICE STATION
    DONCASTER ROAD
    SCUNTHORPE
    LINCOLNSHIRE
    EAST MARSH SERVICE STATION
    ALBION STREET
    GRIMSBY
    NORTH LINCOLNSHIRE
    ST MARTINS SERVICE STATION
    SCARTHOE ROAD
    GRIMSBY
    NORTH LINCOLNSHIRE
    RAWCLIFFE ROAD SERVICE STATION
    RAWCLIFFE ROAD
    GOOLE
    EAST YORKSHIRE
    HESSLE ROAD SERVICE STATION
    181 HESSLE ROAD
    HULL
    EAST YORKSHIRE
    NORTH END SERVICE STATION
    ROMAN BANK
    SKEGNESS
    LINCOLNSHIRE
    MUSHAM BANK SERVICE STATION
    SEAMER ROAD
    SCARBOROUGH
    WEST YORKSHIRE
    FAIRVIEW GARAGE
    WAYFORD BRIDGE
    NORWICH
    NORFOLK
    SCALBY MILL SERVICE STATION
    BURNISTON ROAD
    SCARBOROUGH
    NORTH YORKSHIRE
    HARROGATE SERVICE STATION
    9A-13 DRAGGON ROAD
    HARROGATE
    NORTH YORKSHIRE
    EASTWAYS SERVICE STATION
    YORK ROAD
    CROSSGATE
    LEEDS
    WEST YORKSHIRE
    GARFORTH WEST SERVICE STATION
    SELBY ROAD
    GARFORTH WEST
    LEEDS
    WEST YORKSHIRE
    CARLTON VILLAGE SERVICE STATION
    CARLTON ROAD
    CARLTON
    BARNSLEY
    SOUTH YORKSHIRE
    LANE HEAD
    SHEPLEY
    HUDDERSFIELD
    WEST YORKSHIRE
    BIRCHENCLIFFE SERVICE STATION
    HALIFAX ROAD
    BIRCHENCLIFFE
    HUDDERSFIELD
    WEST YORKSHIRE
    GREENGATES SERVICE STATION
    NEWLINE CARR ROAD
    BRADFORD
    WEST YORKSHIRE
    FITZWILLIAM SERVICE STATION
    FITZWILLIAM ROAD
    ROTHERHAM
    SOUTH YORKSHIRE
    RAVENSTHORPE SERVICE STATION
    HUDDERSFIELD ROAD
    DEWSBURY
    WEST YORKSHIRE
    YORK ROAD GARAGE
    YORK ROAD
    BARMBY MOOR
    YORK
    YORKSHIRE
    NEVISON GARAGE
    FERRBRIDGE ROAD
    PONTEFRACT
    WEST YORKSHIRE
    COAL ASTON SERVICE STATION
    DYCHE LANE
    COAL ASTON
    SHEFFIELD
    SOUTH YORKSHIRE
    ST ANDREWS QUAY SERVICE STATION
    ST ANDREWS QUAY
    HULL
    EAST YORKSHIRE
    SHELF SERVICE STATION
    HALIFAX ROAD
    SHELF
    HALIFAX
    WEST YORKSHIRE
    KINGS LYNN FILLING STATION
    GRIMSTON ROAD
    KINGS LYNN
    NORFOLK
    MARKET DEEPING FILLING STATION
    GODSEY LANE
    MARKET DEEPING
    PETERBOROUGH
    CAMBRIDGESHIRE
    MONKSHILL SERVICE STATION
    BARNSLEY ROAD
    GOLDTHORPE
    BARNSLEY
    SOUTH YORKSHIRE
  20. I think you're getting confused on how duty works Bob. Correct me if I'm wrong, but it's not as a percentage of cost, it's a flat rate per litre. If no duty has been paid on it as aviation fuel and you decide to put in in a car, you have to pay duty. I don't know what duty is levied on it as aviation fuel, I have to admit.
