Donny Wed 3rd April With M.s.v.
Discussion in 'Trackdays & Rider Skills' started by Cream_Revenge, Jan 17, 2019.
  1. Thanks so much!
    I'll come and find you in the morning.
  2. Garage 4. I'll have the black Alpinestar wooly hat on try to keep warm.
  3. Are you coming tomorrow??
  4. It will be fine chaps. The fast group are out first so they will warm the track up nicely.
  5. Bike's all loaded and good to go. Is bloody fresh out there tonight, so looks like I'll be killing off an old set of wets for the first couple of sessions as slick's aren't going anywhere near a 2deg track temp.
    At least the forecast says it'll warm up later in the morning
    See you all bright and early tomorrow
  6. SP are not that bad in cold weather :upyeah:...SC or GPpro would cause a bit of headache with regards to optimal pressure.
    Considering is a cold day, I would run.
    33psi front (cold measurment)
    30psi rear (as above) This might feel a bit soft/wobbly for 1-2 laps.
    Check the pressure once back in the pits and see if the pressure is up or down.... then fit the tyre warmers(if available).
    After 50 minutes adjust the pressure as below.
    32psi front (off the blanket)
    27psi rear (as above)
  7. Enjoy the track day chaps & have a safe ride.
    Shame I could not make it... :(
  8. Am I right in thinking a road bias tyre might be better for tomorrow??
  9. I'm on SCs unless I get wets fitted to the blade.
  10. No bud I’m back on shift tomorrow :( I’m hoping for Cadwell mid April before the forum trip to Belgium
  11. I am going chizel
  12. I only have one set now having had someone bail on me for a second set yesterday!
    • Dislike Dislike x 1
  13. See you in the morning. I am in garage five!
  14. A chilly start in North Yorkshire!
  15. You could always have a snowball fight to warm up if needs be :cold_sweat::laughing:
  16. Bit different in Almeria
  17. Smug mode off.
  18. Up and at um ladies !
  19. Have a great day guys!
    • Thanks Thanks x 2
  20. Rmember, lap times needed men
    TB
