Ducati 899 Not Starting
Discussion in 'Technical Help' started by Nathan Chadderton, Aug 25, 2022.
  1. Potentially a starter fault however unlikely
  2. Was the charger still connected when you did that?
    You only need a simple multimeter to test these things, like this:
    Digital Multimeter Car Battery Circuit Multi Tester Voltmeter Ammeter OHM AC/DC Voltage DC Current Continuity Resistance Diodes Transistor Electrical Test Meter with Test Leads Backlight LCD https://amzn.eu/d/bjpQ3GM
