Hi CC Can I have a code please? There are a few bits and bobs I'd like for my 2011 Monster 1100s Cheers Bob
Hi, sorry to mither you... Can you confirm the weave is all the same on all the CC carbon parts? Got a bit of OCD goin on. God knows how I'm gonna deal with the fact that whatever I buy won't match the cans... Cheers Bob
Hi Bob, The weave is the same match as Ducati corse which is a 200 gram weave. The carbon used on the Termi's (I'm guessing that's what you have) is 220 twill weave to give it extra strength. All our Ducati carbon is 200 gram as is Fullsix & all our other suppliers
Hi Jim, All our suppliers are working hard to get products made, tested & available. I don't have an actual date when they'll be available but I hope to have them by Autum
Hey CC, would you know the size of the boss that fits into the engine of the cnc racing engine oil breather? Also is it straight through with no reed/valve? Thanks CNC Racing Ducati Monster Hypermotard Breather Valve | Conquest Carbon
Hi FE, Yes it's straight through with no reed valve, all this valve is for is to reduce emissions which in turn lowers performance.
I am looking to fit it to a 1098 engine as part of a big breather system. I need to know the diameter of the boss the fits in the block(the part with the o ring/s) Thanks
We have one in stock for a Monster S2R1000 and the bottoms thread is 38mm As CNC Racing don't list this part available for either the 1098 or the 1098 Streetfighter then I would suggest it shouldn't be fitted.
In the picture in the link, it shows the bottom section with an o ring, rather than the screw. The S2R has the older screw in breather but the one in the link is a push-fit with a tang on the side to bolt it to the engine. This is how the are fitted to the 1098. The only difference I can see is the one you list has a vertical outlet but the 1098 has an angled one. I am after the later style you sell. If it has a smaller boss, I can machine an adaptor to allow it to fit. I just need to know if it something I can work with. Just because things aren't listed for a certain model, doesn't mean they can't be fitted. You should know that more than anyone.
