Ducati servicing or diy?
Discussion in 'Technical Help' started by waynem325, Mar 23, 2014.
  1. Checking and adjusting the valve clearances was laughably easy on those engines too!
    For what it's worth, when I did the 900SS belts I used the Allen key method of checking tension. I did use the old "twist through 90 degrees" method on a Golf once, again without problems, but on the Ducati the Allen key method felt a lot more precise to me, although I accept that the other methods are even more accurate.
  2. You can do a twist method, i think it was 45 degree twist. But the guitar tuner is the easiest way I found. I downloaded an app called "gStrings". The frequency of the new belts needs to be 110hz (+-5hz). Run the app, select "tune auto" and pluck the belt. Apparently the original Ducati tool used a similar method before they changed to a laser alignment one (or something like that i read at the time). I double checked this with the allen key method just to make sure and all was good.
  3. Although it will be a used bike it will obviously come with 12 month warranty and fully serviced before I take ownership. Out of curiosity I asked how much future maintenance costs will be and was stunned when told that a basic service (oil & filter replacement, plus fluid/bike check) would set me back £275.
    I remember when the 848 was launched. Didn't Ducati at the time make a big thing about slashing servicing costs for these and subsequent models?
