Ducati Track Bike Up To £12k
Discussion in 'Wanted' started by Richard R, Oct 29, 2018.
  1. Whoosh!! Is that the back end entirely snapped and squatting?!
  2. did he win?
  3. Was right behind him when it happened, very unlucky. The bike looks pretty bashed up but actually it wasn't too bad. It just snapped the bolt on the rear shock, hence the squat. The tanks are fragile, hence my comment to @comesunt Doesn't take much to ding them or pop the front mounts. Knowing him and his dad it'll be mint already. He never gets much luck in Assen.
  4. i have a very light damaged 2016 1299 panigale for sale its a cat b so track bike only it need just nose cone and faring bracket 9k
  5. Sorry but I wouldn’t touch a cat B with someone else’s money OP. It should be crushed or sold as spares only with frame cut or vin removed.
  6. Yup - Curious how a cat B can only need a nose cone and bracket?
  7. i work with a insurance company i get alot of bikes that have minor damaged that for no reson has been made a cat b
  8. In which case you will know that you cant sell a Cat B as a complete item, only break it.
    Write-off categories
    What you do next depends on which category your vehicle is in.
    Category Repairing the vehicle Using the vehicle
    A Can’t be repaired Entire vehicle has to be crushed
    B Can’t be repaired Body shell has to be crushed, but you can salvage other parts from it
    C Can be repaired, but it would cost more than the vehicle’s worth You can use the vehicle again if it’s repaired to a roadworthy condition
    D Can be repaired and would cost less than the vehicle’s worth, but other costs (such as transporting your vehicle) take it over the vehicle’s value You can use the vehicle again if it’s repaired to a roadworthy condition
    N Can be repaired following non-structural damage You can use the vehicle again if it’s repaired to a roadworthy condition
    S Can be repaired following structural damage You can use the vehicle again if it’s repaired to a roadworthy condition
