For Sale Ebay Bikes
  1. Thank christ for the sheep in life,said the salesman to his work colleague.
  2. That's small change for you :eek:
  3. My middle name is masquerade.;)
  4. This went on the RD/LC Crazy Forum yesterday - (nothing to do with me)
    £8000 ovno
    RD350LC ~4L0 Matching numbers import
    New stuff
    MPH speedo
    Chrome fork stanchions
    Hagon progressive springs
    Damper rod & fork seals
    All pinch bolts, fork drain bolts, fork damper rod locating bolts and all copper washers
    Fork end caps, locating circlips and rubber fork covers
    Motul 10w fork oil
    Tapered roller head bearings
    SBS pads & EBC drilled disks (I will swap for original solid LC disks if you prefer)
    Wheel bearings and seals
    Avon Roadmasters
    LC Master cylinder
    Loom, fuse box and battery
    Various engine bolts (JIS screws)
    Crank, rebore and new pistons +1mm std. head gasket
    Chain, F&R sprockets (front -1 tooth)
    Nitron shock
    Indicators, headlamp bowl, switchgear & grips
    Fuel tank (From Mutts nuts not an Indian one)
    Side panels & tail unit
    Front and rear footpegs
    Front & Rear mudguard
    Radiator overflow and 2T tank
    Tourmax fuel tap, fuel lines and clips
    All carb jets and throttle cable
    Radiator and hoses
    Twin horns, horn loom and cover
    Metmachex swing arm with eccentric adjusters and polished brake arm
    Refurbished stuff
    Engine and cases vapour blasted and painted
    LC2 calipers
    Wheels & rear brake drum by CJ Ward
    Bodywork paint by the guy that does stuff for Fastline, graphics from The Image Works
    Std cigar pipes, no dents, rust or scratches, just a blow over with fresh paint
    Seat by Archers in Huddersfield, front tank in very good condition
    Top and bottom yoke & clock surround repainted
    Polished bits
    Fork lowers
    Sprocket carrier
    Various chrome bits here and there
    Bad bits
    Different keys
    No mirrors
    None original clutch perch/lever, black renthall bars & carbon look headlamp brackets
    No centre stand
    1 into 2 goodridge brake lines (original layout but not original brake pipes)
    Fuel cap is not OEM, it has the key in the centre
    I bolted it together
    Good bits
    MOT until 30/11/2020
    V5 in my name.
    It looks like new and it's for sale
    #14429 wroughtironron, Aug 8, 2020
  5. I'd wish you luck but with a LC like that you won't need it, lovely bike credit to you.
  6. It ain't mine - Bounty Bar is Robarano's colour :confused:
  7. Apologies I thought you were parting with your LC I hadn't much considered the colour.:worried:
  8. If he got over anywhere near 8k then a very luck boy.
    Remember yours has all new parts including loom which cost as much as a gold bar now, yours is up there with the best Ron, just my opinion of course :cool:
    • WTF WTF x 1
  9. You could be right,i must have missed it the first time around but i normally don't look at 748 models,only once in a while.
  10. I actually went out to see this bike yesterday morning (before it went onto E-Bay), we'd heard that someone local was selling a race 888.
    If it had been a genuine 888/926 Corse we'd have most probably bought it for close on double the (now) asking price.
    However what we found was a well tricked up 888 Strada...
    The owner is an honest guy who bought it years ago, but now after having 2 new knees fitted can't ride it anymore.
    I told him what he actually had and advised him that it was worth £6 or £7K, but that it had quite a few well sort after 851/888 upgraded parts and was probably worth more if he were to break it.
    It hasn't run for a few years so would need re-commissioning inc' new belts fitted.
    It has a genuine Corse 888/926 rear seat unit,
    Full QB Carbon fairing molded off "Foggy's" NW 200 Winning 888,
    Carbon front mudguard,
    Carbon one piece 888 airbox,
    Twin injectors per cylinder 888 Corse THB's with Green injectors,
    Oil cooler conversion using a 9*6 oil cooler,
    Full 888 SPS/5/early Corse exhaust system fitted with 50mm Carbon cans,
    Fully floating/underslung Corse style rear brake hanger,
    SP5 footpegs/mounting plates,
    Alloy clip-ons,
    Radial Brembo (they look like Billet one's, but I couldn't swear to it) front brake and clutch M/cylinders,
    Goodridge/Earls hydraulic hoses with Red+Blue alloy fittings,
    Alloy SPS/SP5/Corse rear subframe,
    Carbon undertray,
    Carbon Corse covers on the P8 ecu,
    Carbon front sprocket cover,
    One piece Carbon clutch cover.
    ...and a claimed 926cc Blueprinted motor built by Glyn Robinson, who's now the owner of Sports Motorcycles.
    Apart from a bit of dust where it's stood for a few years it looked pretty clean/paint work OK to run with unless you're a "Rivet Counter"...
    This could be the bargain of the year for someone who's prepared to spend a few extra £'s to get it back on the road.
    I didn't get the chance to check the frame or engine numbers, so a possible buyer should make sure to check those. But the owner has registration documents for the bike.
    EDIT The owner isn't a friend of mine and I've nothing to gain from passing on this info.
    My only wish is to help out a fellow 851/888 enthusiast.
    Steve R
    #14438 Steve Robins, Aug 9, 2020
  11. Any pictures of it or is it now listed on eBay ? X
