For Sale Ebay Bikes
  1. I had a punter once who tried to p/X an XJS Convertible that drove all over the shop and I wasn't surprised than when I HPI checked it that it was a cat C! He said I know and I've got a certificate stating it! The trader who stuck him in it told him it was part of the service history
  2. Just because you can doesn't mean you should!
  3. Don't start another thread with anything remotely like this :Finger:
  4. It's been mentioned, several of us are watching it no doubt, but we know not why. It's almost as though we want to like it but don't :)
  5. Looks like a marketing photo so not the actual bike perhaps?
    Previously registered overseas...
    55 plate but date of first reg is 29/1/08...
  6. I saw that bike last year when I was looking for a new R...the guy was selling a 999R which was lovely but basically too similar to my 749R to be exciting *
    ...he did however have this BMW which was way more interesting than his 999!
    Beautifully made, very nicely styled, fantastic paint job, sounded like a Heinkel 111 when he started it for me!
    Thing is, you'd need the full ginger beard/check shirt/skinny jeans combo to pull it off.
    ( *Ended up getting the 1098R instead)
  7. Well, I'd never argue that you made the wrong decision in buying the 1098R, but I bet you wish you had both in the garage.
  8. I know it's been up for months and months. If it was right I'd have expected it gone by now.
  9. Rothmans Honda NSR250 on the 2stroke forum ( a member's bike) :-
    This is going up for sale in a few weeks time
    It needs an MOT (being done 1st week of Sept) whilst I wait for the new dating certificate from Honda, then it will be registered on an age related plate as 1 owner (me). You could be the 1st owner if you do the registration
    Genuine Honda fairing and tail piece
    Usual SP extra's are fully adjustable suspension, dry clutch and magtek wheels.
    If you are interested send me a PM
    Bike stands me at £7,5k will take £7k as it is now or the full whack when it's registered
    Bike in South Manchester
  10. He would probably do well to word his advert a little better. Terminology like "Full whack" do little to inspire confidence.
  11. Just gone up on the RD LC Crazy Forum - a members bike (looks gorgeous)
    my mate is going to be selling his kr1s r from this weekend
    he is looking for 3500 for it the zeel wants progamming for it
    it has dymag rear wheel kr1r carbs, inlets ,cr gearbox ohlins fork internals in zxr400 forks im sure it has ohlins rear also
    titanium jl pipes yes titanium ! its very very nice all plastic coated and re-built he has been through everything on the bike
    i will get pics as soon as i can and full spec engine is all fresh plastic coated and re built fully with new parts
    he also has another kr1s engine thats all been fresh powder coated that wants putting back together
    that engine is complete as well
    bike and parts will be on other forums and e bay but im putting on here first so you get first dibs
    tank is in kr1 r paint work just needs a bit of finnishing like zeel setting propperly just the pv opening times i think
    it has race fairings on i think .
    i will post more when he gives me the info ,he got it from a forum member a while ago and it wasnt good so he went through it all and fully did the motor again ,its the best spec kr1s i think ive seen .
    it would make a beast of a track bike
    his words
    I've been slowly doing bits with the KR for about 18-month now and just when it's nearly there, I've been tempted by another bike but the wife won't let me bring another home without making some space first. Sadly, the KR drew the short straw so i've decided to offer it up for sale...
    Kawasaki KR1-R spec KR1-S
    Needs a small amount of work to finish. Engine just rebuilt (seals and gaskets) and almost everything powdercoated (including the engine cases). It starts and sounds lovely and crisp but the KIPS valves aren’t operating correctly. I think it’s either the zeeltronic power valve controller that is faulty or just me that doesn’t know how to set it up correctly (I do admit that I don’t know how to set it up but have had a play with it and can’t get it working quite right). Other than the KIPS valves and probable carb setting up once they are working correctly, it just needs paint.
    Chassis spec
    RGV banana swingarm
    Dymag rear wheel
    ZXR400 front wheel
    Ohlins rear shock
    ZXR400 front forks with Ohlins internals
    New steering damper
    New chain
    Galfer rear disc
    New Michelin cut slicks
    Quick action throttle
    Digital dash
    Push button ignition
    Quick release fuel cap
    Zeeltronic programmable ignition
    Zeeltronic CDI
    Zeeltronic programmable PV controller
    New satin black powdercoat on frame, swingarm, front wheel, rearsets, top yoke etc
    Engine spec
    New gunmetal grey powdercoat to all casings
    New seals
    New gaskets
    Lightened flywheel
    Flowed crankcases
    KR1-R spec close ratio gearbox
    KR1-R spec 35mm flatslide carbs
    KR1-R spec carb to airbox rubbers
    V-Force 3 reeds
    KR1-R fuel tap
    F3 KIPS valves
    Billet KIPS valve pulleys
    Jim Lomas Titanium pipes
    Running on premix but oil pump is fitted and working if wanted to change back
    Spares
    Gearboxes (2 or 3)
    Clutch baskets (3 or 4)
    Clutch plates
    Clutch inners
    Casings
    Cylinder head
    Power valve servo motors (2 or 3)
    Flywheels (3)
    Generators (2 or 3)
    Many sets of Reed blocks in carbon fibre and carbon Kevlar
    Set of clocks
    Wiring looms (2)
    Regulator rectifier
    Rear light
    Front brake discs (2 sets)
    Front brake callipers (2)
    Seat
    Assorted bodywork (all fibreglass and all needing some repair before paint)
    Assorted clip ons, new levers, switchgear, torsion bars, suspension linkages etc etc
    V5 present and in my name
    £3500
  12. When i saw the first bit kr1-r, it skipped a beat, i think there is only about 4? in the country. good spec that one.
