I did. The only thing I didn't take a photo of was the lug but it's pretty much the same as the Bursig. The lug sits proud of the frame but it needed to be so that you can tighten the bolt from the other side. I was thinking of using a grommet to cover it maybe? New pin didn't arrive today but to be fair I think it will be a few days.
22mm socket for the adapter insert? TIP: stick a few pieces of insulation tape over the edge of the socket to be sure you don't mark the frame when torquing the stand adapter insert ;-) The top one is a standard rubber bulkhead bung/grommet that I managed to squeeze over the Bursig adapter insert.....doesn't look that good in reality and keeps popping off. I'm now thinking of getting a Delrin surround made, hex shaped hole to sit over the adapter insert, flush with the top of that and maybe shaped to look like a frame slider. Hold that in place with a frame plug like these that I already have (smaller diameter collar section to fit in the adapter insert) I got these off an Italian chap who did have some Fleabay auctions running but I can't find any now: [email protected] Really nicely made ally anodised plugs.... The larger lower frame plug (swingarm pivot bolt cover) is a cheap as chips plastic cap that looks like it was made for the job... Spec/details: Item code 085045069903 45mm Ribbed insert, black polyethylene (Ld-PE) product information Minimum quantity available from Skiffy is 50 (25 pairs;-) - they must be available individually somewhere though.
Sorry Bob I don't...........I suppose someone could place the min order with Skiffy and sell them on to other owners, if nobody else volunteers over the weekend I'll set something up.
I found this place Bob Round Chair Tube Inserts, Plastic Plugs, Chair Inserts, Plastic End Caps & Plugs and more... so will give them a ring on Monday as I would like to get a set of frame plugs.
Great find Tony........they're old school or what, OD in inches :-O (shame they don't quote the ID of the tubes they fit)
Count me in also please. I will update on the lift later but there have been a few issues with delivery of the correct kit. Nothing major and the guys at Envy have been great. It'll be worth it in the end and I'll have the capability to get different fits so I'll be able to lift both of my bikes and my wife's. So that's a good thing
Well at long last it's all sorted. It was a bit of a long trip but I've eventually got there. It works brilliantly and does pretty much everything I wanted i.e. gets the bike off the ground and allows it to be moved about easily. One of the reasons I bought it was that I thought that the different plates for different bikes could be fitted to the lift. Not necessarily the case. There are different height lifts so I might not be able to do as I intended. A pity really but not the end of the world. I'm not sure how much value there is in posting pics as they would be pretty much the same as the ones Andy has already posted. The guys at Envy are good guys and were always on the end of the phone to help. I also like the fact they're a British company .
Hi Anthill Only picked up this post now....if you happen to have any left from the 50 pack then let me know what you want for them and I will get the cash to you! .
Sorry I didn't post again but I did speak to them & they didn't have any stock of the sizes required. They would only manufacturer another batch for a larger order & suggested I contact them again in another Month or 2.
For 'damodici' DIY cover for the Bursig frame adapter / insert protruding form the Multistrada 1200 frame. Google part number 009 0250 220 03 for the black p[lastic cap (original left - cut down to fit, right)
Cheers Andy unfortunately though the seller withdrew the item from sale but I've shown my interest and intent to buy should it become available again. its a pity as I could really do with one like that yet can't afford the new price
Try this tip: if standing to the left of the bike and holding it (upright obviously and it's off the side stand, turn the bars full lock to the right. Just hold the left grip (or rear grab rail or even palm of hand on tank) lightly and see how much more stable it becomes stationary. Much better balance point with the front fully turned. With practise, you can actually walk around the bike just using light hand holds on various parts and it remains quite stable. Normal rules of 'bike gravity' still apply if it gets too far from the vertical and don't do this pissed showing off. ** EDIT: see post 38 below
Glad you posted that because I was looking for the envy stand online and can't find one Problem with this one is that it doesn't look like there's a multistrada 1200 adapter
Phone Demon and ask for the manufacturers contact info and see if something can be done ;-) Suspiciously similar!..........good find and assuming the quality/build is ok a great price. NO!....wrong way round Marty ;-) Standing on the left of the bike pull the left bar towards you and the balance of the bike will be biased to the left i.e. towards you. I go for half lock as I find that full lock makes the bike want to 'fall' left too much. As Marty said with a little practice (maybe a mate on hand just for comforts sake;-) you'll be surprised how quick you get the knack. As stable as you could expect.......I wonder if the Warrior is as sturdy and so stable. Wheeling the bike around on the stand is fine as long as the surface is reasonably smooth (small wheels;-) See the video:
Has anyone tried the Abba sky lift, it's the same price range but lifts the bike far higher, in my opinion better to work with. abba Sky Lift - product details - Abba Stands, UK
I've had it, albeit for a different bike but eventually sold it. It's well made and simple to operate like all ABBA products. Whilst it is convenient if space it limited I found myself gravitating back to my traditional flat bed hydraulic lift. I find a flat lift more convenient when using tools, and it psychologically gives me more confidence leaving it raised. I now use the flat bed in conjunction with a traditional ABBA stand and their optional front lift arm when needed. If space is an issue then the sky lift is perfect, no doubt. You do have a mental hurdle to get over before hoisting your pride and joy at various angles though
