1200 Error Code - P4031 / C0031 Speed Sensor
Discussion in 'Multistrada' started by Stavrich, Jul 23, 2018.
  1. Good work. that point of the small loom going into the Larger loom is where i stoped thinking thats well supported and no need to continue.most impressed by your efforts,
  2. HI guys,
    I'm reading now the post, but I had the same issue few weeks back, fixed by a garage in London as I don't have enough tools at home. to me was the wire broken in the front as well, plus my fuel sensor was off as well.
    Nice job Stavrich
  3. Hi MTS users,
    I had the same problem on my MTS 1200s 2014 (Speed sensor error, ABS off, DTC off) it happened generally when speed was higher then 160 km/h. I started from:
    1. Front abs sensor
    2. Rear abs sensor
    3. Front accelerator located on left fork
    4. Front accelerator located on body
    5. Rear accelerator
    still no results – frustration grows
    6. voltage from module 2.45V it is OK
    7. impedance of sensor also ok
    8. cables in all critical places – ok
    I am starting to feel desperate
    9. I tried to contact local ducati service. They suggest to change tires.
    10. Front tire - no result
    11. Rear tire - no result
    12. Front and rear distance between time wheel and sensor.
    Frustration level expert
    Be patient finally I have solved problem.
    13. Last changes solving problem: front fork oil + front fork seals + front wheel bearings
    It solved the problem but don’t ask why.
    This bike is really nice but can knock you down.
    I had also another case, after 1 hour on highway with continuous speed over 200 km/h my engine stopped. After short investigation inside my engine I found the shaft broken near the magnetic wheel.
    New shaft cost 4000USD.
    Fortunatly I was able to buy a used engine only with 7000 km. Cost 2000USD.
    After engine exchange everything is ok but I can say MTS it’s like very nice blond girl.
    Love and hate – probably You now it.
  4. That cable is a common problem, mine went a few years ago. It is too tight and constantly under tension.
