Fitting Pistons/ Rings Into Barrels 900 Superlight Help Please
Discussion in 'Supersport (1974-2007)' started by KG900SL, Apr 12, 2015.
  1. How clean is that workspace?? Looking good there.
    Yorkie
  2. KG900SL,
    Could others confirm, thought head nuts were 3 stage torque 15 / 24 / 41Nm. Where did 20/30 Nm come from?
    Cheers Gaz.
  3. Gaz, you are correct, I unfortunately posted the incorrect torque values that I had scribbled on a piece of paper.
    15 / 30 then 42 +/- 1 old studs 39 +/- 1 Nm new studs, studs I believe were replaced to the newer type in 95.
    Regards
    Kurt
    #23 KG900SL, Apr 20, 2015
  4. Kurt,
    Good, that's OK then.
    Cheers Gaz
