Foam Instrument Panel
Discussion in 'Supersport (1974-2007)' started by gurth, Apr 30, 2023.
  1. DM sent.
  2. Gurth,
    Looks like Desmo sorted you, but just wondered if you got the files.
    Cheers Gaz
  3. Yes received thank you @gaz92!
  4. I see this kind of foam used in flight cases everyday.
  5. I would look into laser cutting this if you can...been using one today...really simple pieces of kit and you could cut directly from the dxf file.
  6. I have sold the dash now for info
  7. I got one from Brancato. It was a fair while ago though.
  8. Hi Gaz,
    I would like to get one of these foam IP surrounds cut, would you mind sending me the /dxf file please?
  9. Darrell,
    No problem I will have a look for it.
    Cheers Gaz
