Free Diagnostic Software
Discussion in 'Technical Help' started by chrisw, Sep 15, 2013.
  1. Drawing: 28640701A
    Hardware: IAW59MHW010
    Omologation: 59MAJ
    Software: 0130DO01
    Tester: DUC
    Date: 2004.05.14
    MHW010,Can it access by a version?
    Naoki,From,Japan
  2. JPDiag will fully function for the IAW59M ECU without a licence. Use the 'slow init' setting.
  3. cable test、time out,WHY?
    Ican read BIN(GUZZI REDER),
    Writing is not made.
    If it has a map of s4r (996)
    Would you divide?
  4. Thnks,Chrisw
    I have ,S4RS Testastretta,5am,ecu,and
    N
    Caredcood,RED key,
    I wish,5am,tps-rest,usefor,996s4r
    996s4r,metter It was broke
    Please advise it
    Naoki ,fromJapan
  5. Hi
    Iaw5*、Does the L line become the pin which is what?
    Naoki ,from Japan
  6. Chris do you have a need for a 620ie ecu that seems to not start up?
  7. Hello
    Just to give a bit of information, i have had problems connecting to software when engine was running, luckily today after tb balancing and idle setting i have tried last time... the hardware manager chosen com port 16 for me(other usb socket port 13) just desperately changed com port for no 1 9advanced com settings) and voila! now i am able to do trimming. program stucks every couple of times but it works at least !!!
  8. Try putting a USB hub between the Computer and the bike.
    Something like ADVENT HB112 4-port USB 2.0 Hub Deals | Pcworld
    It doesn't need to be powered and should solve the hanging issue.
    As for com port numbers, try to keep them under 10.
  9. I have put 4 of different ones also made myself ferrite filters and to the cable with no results up to today. I am happy to hang up every now ant then as long as i can do something :)
    Could not even get tobtrimming menu before when the engine worked...
  10. Old thread resurrection :)
    I've been using this thread to help me connect my ecu to jpdiag.
    My led illuminates as soon as plugged to usb
    I have a license type later ecu
    Everything is in French.
    So, do I have to solder across pins, why does this need to be done, and how do I number the pins?
    I have acquired the licence attached in an email, how do.i use it?
    Can jpdiag be set to.load in English?
    Cheers all.
  11. The language problem is because you did not give the install .exe file admin rights. Look in the JPdiag folder for the .ini file. Open it in notepad and change Language to 1 from 0. See if that works. The WinChipHead lead needs pin 4 and 5 linking. These are both earths. There are pictures here JP Diag Gouge
  12. Thanks Chris.
    Into what file do I save the licence that arrived by email?
  13. Place the cle.lic file in the JPDiag folder
  14. Hi,
    does this work on a 2014 multistrada 1200s GT? Sorry if a silly question
