Fuel pump just clicking on 900ss
Discussion in 'Supersport (1974-2007)' started by YellowDuc, Jun 18, 2013.
  1. Thanks again AL
  2. Glad you've sorted it :upyeah:
  3. Hi
    Just a little update on the fuel pump clicking issue. It turned out to be the main/iginition relay at the front of the bike under the headlight - the yellow relay.
    The Ducati parts guy on the phone had no clue what i was talking about. So ened up with the same rating etc from HALFORDS!! their relays have a diode in to protect the coil from return voltage into it after the relay is not energised/off.
    just had to check the order that the wires wer in on the connector, so that the voltage runs the correct way through the relay.
    Did not matter on the yellow OEM one as there is no diode. First attempt blew the main 30A fuse, thats why i checked - Horse and Cart i think :)
    Opened the Halfords relay and cut out the diode and it works fine, even fits pretty good into the rubber holder all be it the Halfords relay is a tiny bit smaller.
    Got a second one as a spare, swapped the coil wires over in the connector, plugged it in and everything works great.
    I hope this will help anyone else with this issue, as everyone has been so helpfull to me to try and resolve this.
    Cheers
    Mark
