Garage Alarm ...
Discussion in 'Ducati General Discussion' started by Packman, Aug 13, 2019.
  1. He uses the security cameras
    As long as you clear down videos apparently it’s great
  2. Do you have a link to the kit?
  3. Will PM you :)
  4. https://biketrac.co.uk/
    If the bikes armed and it moves more than a couple of feet you get a call right there and then. You can also view online exact position and even battery voltage.
    Highly recommended
  5. That is another option. Got it myself, in addition to the CCTV and ground anchor in the garage.
  6. Ive got Biketrac on all of my bikes, do find after a couple of days if I have forgot to plug in the trickle charger back in from a ride that you get a low battery alert.
    Would definitely recommend but bike needs to be on a trickle charger otherwise it kills the battery, not a problem if you ride a few times a week, but for me it’s more like once a month :rolleyes:
  7. I can easy leave mine a month and it will start.
  8. But yours isn’t a ducati... ;)
  9. True, Italian electrics Vs KTM :cool:
  10. If you have line of sight - I would recommend a high powered hunting rifle..... only joking.....
    You can get the land mine units - which basically fire blank shotgun cartridges
    Mount them on the doors and the bike - so that they go off... generally thats enough to keep people away...
    Then that combined with alarm to your phone - would buy you time.
    You would need 2 large leisure batteries - one on charge and one in the garage
    Would support Mini wifi unit and a camera, and a blaster alarm - you would need to mount them up high...
    As others have said - the fact you have lots of chains will buy you the time to get there after they trip the door... if your home - but if you are away - probably not....
    Any reason you have to use a lockup
  11. Smoke bomb from stage supliers about £15. They come in different colours but will all fill the garage so they cant see and attract people who will probably call 999 thinking its a fire.
  12. Add some strobes and they'll stay for a rave
  13. then you could charge enough to get another KTM
  14. Me too please @Pfk
  15. PM’d :):upyeah:
