1200 Goddam Mother#%%$1ng Rear Nut...grrrrrr
Discussion in 'Multistrada' started by damodici, Jul 21, 2014.
  1. Bet there was a few tears after he used that pipe wrench on the Wife's ankle. That looks nasty.
  2. Great big torque multiplier is watcha want ;)
    Check it isn't rusted on :D
  3. Well I'm yet to give it another go, I've got a mate coming round tonight who quite coincidentally has the nickname Brutus, I shall sit on the bike and he can use the standard wrench and small bar.
    Failing that I move to the Stillson around the socket + scaffold bar.
    And failing that it'll have to be rattle gun time ........ Oh the joys of wheel removal
  4. [QUOTE="990Glen, post: 394342, member:
    not wanting to piss on folks chips, but I've never really understood how we get so many threads about a wheel nut.:confused:[/QUOTE]
    Just dont mention tyres, tax discs or Multistrada's going tits up.
  5. if the pipe wrench slips on the nut I doubt you will get a socket/rattle gun on after... Then you'll ave to do what I did a few years back and grind it off.. or sell the bike cheap!:upyeah:
  6. Ahh... wrench around the socket! sorry... That's a bit safer for sure! still selling it cheap is an option:upyeah:
  7. ITS OFF!
    fooooooking hell, what a bloody mess about.
    Honestly Ducati...... Single swingers look good but Christ you don't half make us pay for it.
  8. Guess you'll be wanting top dollar now....
  9. I'd take single swinger over twin any day. Easy peasy compared to lining shit up. And get a impact wrench yer cheap skate!
  10. Why can't they do a 4 bolt, as per the GS at a paltry 90 ft-lbs or so per bolt?
  11. I will do..... But in about 5000 miles :)
  12. You'll need it earlier than that to put the wheel back on.
  13. Nah, balls to that.
    The big bar will do and a good yank on the torque wrench to nip it up :)
  14. Quality high temp grease on the spindle threads before replacing the wheel nut! ;-)
  15. Is that right Andy? Always gone for not adding grease if it didn't have it in the first place as it affects the torque. My mechanic didn't add any to mine the other week. But then he also managed to undo it without too much arsing about too. First time wheel has been off since new most likely too
  16. I always grease it too. Which means that the torque will be consistent every time it's done up. It should be easier to undo and the thread will wear if it's not greased and being a fine pitch that's not a good thing.
    Oddly in the manual page for torque settings there is no mention of grease but in the section on re-fitting the rear wheel it clearly states "Clean the mating surfaces and lubricate the threaded end of the wheel shaft with the recommended grease."
  17. ..there we are.....you beat me to it this time Derek lol
  18. So grease up :upyeah:
  19. greasing the thread will lower the friction, and in doing so likely mean the nut is over tightened.
    The grease will probably melt over time, and also attract dirt into the exposed thread. It might protect the thread from corrosion, but the dirt that will then be pushed up the thread as the nut is undone will wear it more than anything else, especially if any sand grains get embedded in the soft alloy nut (been there, done that).
    Clean the threads yes, grease them no.
  20. Manual says grease.....good enough for me.
