Heated Grip Probs
Discussion in 'Technical Help' started by Robot, Dec 28, 2018.
  1. Thanks for this Mentalist bro. My dvt 2015 base....13k miles LHS grip off. RHS still on. But engine light too? Any hope for a cut n shut repair on the dvt heated grips?
  2. Don't see why not Bandit, 1st port of call would be to disconnect the left grip wiring connector, use a multi meter to see if there is an open circuit on the heated grip wiring and also if there is a 8-12v feed going to it. If you have voltage to the connector then the grip must I presume have an open circuit and be faulty.
    R&G grips have the same resistance so f you don't mind having a slightly different grip pattern then buy a set, cut the connector plug off and solder into the OEM one.
    a quick ebay search and loads of left ones for sale £15. Just make sure you buy the right size diameter for your bars.
    hope this helps.
    https://www.ebay.co.uk/itm/R-G-RACING-REPLACEMENT-LEFT-HAND-SIDE-HEATED-HANDLEBAR-GRIP-22mm-7-8/191804953009?_trkparms=aid=555018&algo=PL.SIM&ao=1&asc=20131003132420&meid=692e9a93a4964793a064b21b17e18bdf&pid=100005&rk=1&rkt=12&mehot=ag&sd=323398465710&itm=191804953009&pmt=1&noa=0&pg=2047675&_trksid=p2047675.c100005.m1851
