Hello from across the pond! :)
Discussion in 'Newbies Hangout' started by cali_rsv, Dec 22, 2012.
  2. Sarcasm noted lol. I will try and keep up!
  3. Hello Justin
    You use whatever on meter? Origin or digital ?
    Thanks
  4. Gauge cluster? OEM Analog.
  5. The fork are planned for reçevoir the slice for the snail of meter in the wheel?
  6. Speed sensor? I used the OEM one from the 998.
  7. The montage is p´n'p for fork 1098 to 998????
  8. I don't understand your question.
  9. Sorry for my english on use translator
  10. You need the 1098s lower triples which is a 56mm ohlins set up. Everything else should work. You need the 15mm offset brake rotors from a 748R.
  11. I does not understand(include) how the meter can work being to give that he(it) are not digital
  12. That bike is pure filth...welcome :cool:
  13. Probably the best yellow one I have seen ! Welcome. I am on MS too so between that board and this you have pretty much got things covered
  14. You put an abutment on the foot of left(awkward) fork for the trainer of speedometer?}
  15. Welcome to the forum
