Help Wanted For Badly Misfiring Bike!
Discussion in 'Technical Help' started by laava, Apr 8, 2019.
  1. You must know Steptoe and his boy....
  2. On the Dvt are both inlet and exhaust cams variable control ?
    Do both cams have a cam sensor each ?
    At idle in live data are the map sensors reading the same values ?
    If you load the bike up in say to high of a gear and make it pull does it pluck and cough more than slowly winding the bike up the Rev Range .
    On cars I have had coil sticks play up just because they have had to be pulled out ...it can just upset them and give the plucking / coughing/ jerking symptoms....but so can a lot of other things too
