1260 Hill Assist - How Do I Disable It?
Discussion in 'Multistrada' started by stevie555, Apr 30, 2019.
  1. If it doesn't release when you pull away, something is not working correctly.
  2. I rarely use it though it is extremely useful in some situations, especially when riding with a pillion.
    Try using a bit more throttle when pulling away.
  3. As others have already said
    It should release when you engage the clutch to pull away
    If it doesn’t do that, it isn’t working correctly, get your dealer to take a look
  4. Yep, agreed it isn't working correctly. I also agree that Ducati should have given us the option to disable it completely though, especially since it can obviously act up.
  5. Thanks for all help. I'll talk to my dealer. Perhaps the dis-able option will be available in a future software update.
  6. How do you enable it? i haven't got it to work so far and i could have done with it on a couple of occasions.
  7. Just pull on the brake lever really hard when you're at a standstill .You'll get a little yellow icon on the dash to confirm its on. It'll then flash as it's about to switch off about 10 seconds later.
  8. Ok, thanks will give it a try, does it work if i do the same with the rear brake instead?
  9. Short answer, yes!
    Long answer, from the manual:
    Vehicle Hold Control (VHC)
    The Multistrada ABS is provided with the Vehicle Hold
    Control (VHC). This system, when activated, keeps
    the vehicle at a standstill by quickly activating the rear
    brake with no need to apply braking power to the
    brake lever or pedal. The system allows the user to
    enjoy a more comfortable restart while just having to
    control the clutch and throttle pressure.
    This function is activated when the user, with a bike at
    a standstill and with folded side stand, applies a high
    pressure on the front or rear brake levers. It can be
    activated when vehicle is turned on (Key-ON). Upon
    its activation, according to the vehicle status, the
    system calculates and applies a pressure to the rear
    system by acting on the pump and the ABS control
    unit valves.
    The system can be activated at all ABS levels
    (including ABS OFF) and its activation is indicated by
    the following warning light turning on. The same
    warning light will start blinking when the system is
    about to release the rear brake pressure and thus to
    stop keeping the vehicle at standstill: pressure will be
    decreased gradually.
    Note
    This function is disabled when the user starts or
    pulls the front brake lever twice in close sequence or
    after 9 seconds from the activation, or when the user
    opens the side stand.
    Warning
    The system can not be compared with a parking
    brake: during its activation we recommend keeping
    your hands on the handlebar in order to take control of
    the vehicle as soon as the system is disabled
  10. I must admit I love it.
    Over Easter I was riding some very naggery roads with all sorts of horrible steep junctions I must admit it did come in very useful.
    Under normal riding I don't find it activates.
    As others say the only thing I would change is the duration as 10 seconds isnt long enough.
    Desperado
