How To Lighten A Rear Disc
Discussion in 'Technical Help' started by comesunt, Mar 9, 2015.
  1. To measure wheel speed for speedo.
  2. Track bike tho, so dtc maybe?
  3. @comesunt which battery did you buy?
    Are these the the type that require a special charger?
    #43 Nelson, Mar 12, 2015
  4. Yep, wheel sensor is for speedo, but I need it for traction control...
    @Nelson I got my lithium battery off carbon quest. They recommended a special charger, so i got one... I've seen teh charger for sale at a simliar price; but seen the battery for sale for less
    I had an alternative lithium battery for my 748. I can't recall where i got it from; but my 748 lithium seemed to spin the motor up much faster then the original. The unit form Carbon Quest does not spin it so fast... I'll try to find a link to my 748 battery; but I'm just in from the pub so that might be a while ;-)
  5. @Mr.R thanks for reply...
    As I don't ever really use the rear; heat shouldn't be an issue...
    So I'm guessing that I can drill fewer, bigger holes and be ok??
    Thanks,
    Bob
  6. i have drilled discs before and never noticed any substancial heat imput , opening up the orig holes should have virtually no heat imput at all,, providing it is done properlly , on most drilling machines there is a coolant feed anyway
  7. my mate is a precision engineer and has made aluminium rear disks for a top tt racer, he doesn't use his rear brake but it has to be there hence aluminium......at end of races its still intact and unused.
