I am putting my 848evo back to stock and am removing the slash cut termi cans to go back to stock. I also want to remove the dp ecu and put the standard one back in but wanted to check if this was a DIY job. Is it find it, unbolt and unplug it and put the stock one in or does it need any software tweaking ?
Yep plug and play What you doing with the slash cuts??? want to part chop some standard carbon termis?
oh sorry, its throttle position sensor. I had to get this done on my 1098s, I think the panigales do this themselves but the earlier 848/1098/1198 need to be reset by the dealer. May be worth checking
Im soon to be fitting Termis etc, what are the symptoms of a tps that needs adjusting? is it a Main dealer fix?
DIY Free Diagnostic Software | Ducati Forum Free Andoid based Ducati Diagnostic Software | Ducati Forum
I fitted slash cut Termi's and dp ECU recently only ridden for a couple of hours but all seemed perfectly fine. So long as it continues to appear ok I'll just be waiting till next service to have the Tps checked/reset.
I've seen chrisW do this to my bike and seams pretty straight forward. Also got the wires to do it myself. Only cost a few quid.
Ecu removal/replacement takes seconds. I would think the exhaust system change would be a bit more excitement depending on if you're repalcing headers as well. Also the emissions kit with standard system. Looks like your set to go.
