It's Italian And Ends In Ti
Discussion in 'Builds & Projects' started by Crossbreed Cycles, Aug 29, 2014.
  1. They'll be fine - I used them on mine - looking good!!!!! :upyeah:
  2. [​IMG]
  3. Would that rear shock be up to the task?
    • Disagree Disagree x 1
  4. It shouldn't be a problem, there are sleeves in the mounting eyes, so I can actually use M12 bolts instead of M10. The shock is designed to hold a large pillion, who would probably add more rear weight than this bike will have as a solo.
  5. Coolio :cool:
  6. Stunning.
  7. This is so cool loving it......in that rendering is that the fuel on the back, if so, not sure the bike will do more than 75 yards between fill's !!!!!
  8. The 3D software reckons the tank is 15 litres, that should be good for 60 miles, definitely not an endurance racer.
  9. Very nice job. What you got planned for the cooling/radiators/fans ect?
  10. as said already, this is coolest bike project/thread on here bar none.
  11. I'm not sure, the only water cooled bike I've owned was a GT750. I need to research a lot, the radiator is going to have a huge impact on the final look of this build. I want to do everything on this build but I may give this job to an expert.
    Thanks Chris
