1200 Keyless Ignition
Discussion in 'Multistrada' started by Xr650, Apr 22, 2014.
  1. Is that a gen piece of kit or some Chinese fake leather ! :)
  2. I like that idea but drills n transponder keys scare me to death .
  3. Genuine Ducati
  4. You need to open up the transponder key housing first, just as you would do to replace the battery. It splits in half easily but you have to be careful. Then you drill the little holes in the two halves, well away from the electronic gubbins. Snap the two halves back together, and put a key ring through the hole. Ducati should have done this in the first place, obviously.
  5. Cheers for that sounds easy enough....little Saturday job then
  6. Pete is absolutely right, this is really easy to do, even if you are not that practical!
    Take it easy, split it as Pete says, take out the electronic stuff (which I think can be detached) and actually you don't even need to drill. Simply use a small section round file and gently file out a section of plastic in each half, check it a couple of times to suit the diameter of the key insert and there you go. The maximum diameter is likely to be between 3-5 mm at most. Re-insert the electronic gubbins, snap the two halves together, job done......:rolleyes:
    Total task time, circa 10 min :Smuggrin:
    Good luck, take your time it's not difficult.
  7. Cheers for the run down, going to do it,today nearly set off with key in the seat locker.....rookie error
  8. I thought the monster doesnt have keyless ignition?
  9. This is a ‘Multistrada’ thread and now 6 years old. Andy
  10. I wondered why no-one had the later style key fobs :D :D
  11. As an aside, does anyone do replacement filler cap assemblies that don't require a key? I can't say I'm especially concerned about the likelihood of someone pinching my petrol, and it would make filling up much more convenient.
  12. I’d be more concerned about someone putting something in it rather than taking anything out!
  13. Slingshot racing make them apparently, as I have 1 that came with some parts I bought as a package off eBay.seat, leavers,guards,etc If anyone is interested?.
    Multistrada 3013.
