Leads: Additional Battery Earth...
Discussion in 'Parts, Accessories & Clothing For Sale' started by Exige, Apr 16, 2015.
  1. Not if they are pictorial :) - anyhow, it's Aircon that needs the help there ;)
    • Nuke Post Nuke Post x 1
  2. Crimping is best, don't listed to Aircon all the time :) the crimps I'm looking at are stronger than the cable and don't fail :Wideyed: might be too expensive though :(
  3. Photo shoot?
    So now you're a model as well - is there no end to your talents??
  4. Yes, but I wasn't looking my best on the day :(
  5. I know the problem - tell me about it...
  6. What is the crimp made of?
    You may need a very hot iron, flux and/or silver solder (as close to 100% as your budget will allow).
  7. Explain your self...don't become too American and say something without explaining why.
    And I won't even go into the spelling!:Angelic:
    • Drama Queen Drama Queen x 1
  8. I did so, as I had one on the 998S.
    This pulls a lot of current when starting. The USA stuff did a great job and I liked how they had done it....but I knew it was worth the money compared to my time spent else where....:Headphone:
    Any how....why I'm I now a deity ?:(
    Have I managed to make a comment that has risen me above other men (or at least in my own head/thread)?:p
  9. 'Tin' both the cable and the connectors before you try soldering them together..........that way the cable is 'solid' inside that first 10mm or so.
  10. The tinning is a good idea, as it allows you to identify which part isn't taking the solder (or silver).
    Please take note of what I said in my post about supporting the "solid" part of the cable.
    TOP AIRCON TIP (Patent Applied for)*
    Take a small piece thick cotton rag and soak in water.
    Using a metal crocodile clip place the wet rag around the cable, close to the joint being heated/ soldered.
    This will prevent that part of the cable exceeding 100°C and therefore melting. Further it stops the "solid" wire travelling too far up the cable. So long as the rag stays wet you can carry on applying the heat.
    Note if you haven't got very much heat (soldering iron too small) then this may prevent a proper joint forming.
    * This is a joke before I get a whole load of "drama queen" likes.
    • Drama Queen Drama Queen x 2
  11. When I built mine I just used the gas hob to heat up the ring terminal (cable inserted). The solder was then drawn into the terminal by capillary action. Covered it with shrink tube afterwards. Result was solid.
  12. When soldering, I keep burning the sweet corn and tomato pips, so crimping may be best.
  13. I found myself cringing when I was reading that :Wideyed:
  14. I would have used my mini butane torch but it has died. :Banghead:
    Works better than a soldering iron though.
  15. :Wacky:
  16. There is some useful stuff amongst the drivel...
  17. Nob, but I am drunk, so you might not be a nob, you nob :Happy:
  18. Were you in the dunny at the time? :Yuck:
  19. That's Mr. Knob to you.
  20. Sorry :( Mr Nob :)
