1299 Loosen Rear Wheel Nut
Discussion in 'Panigale' started by Brom66, May 21, 2018.
  1. Snap on 4 ft breaker bar won with help from a scaffold tube ffs really..
    Put axle stand under socket an covered wheel up with carpet.. I believe the dealer did it this way
  2. If that is the case, I'd be looking for another dealer. Glad you are sorted. Andy
  3. Exactly the combo that I did on the multi. Snapped the knuckle off the first breaker bar :confused:.
  4. As others have said, get an impact driver and do it yourself. Also worth considering getting a socket designed for impact driver use rather than an aluminium or the standard socket set chrome vanadium steel type.
    Here’s a link to one:
    https://www.ebay.co.uk/ulk/itm/182093989720
    #26 J0n3s, May 23, 2018
