Lotus Superbike.
Discussion in 'Other Bikes' started by Wrecked, Jan 15, 2014.
  1. Apart from Triumph and Norton, you know, just saying...
  2. It's got a pipe exit, so not electric I would think.
  3. Lotus claim it is powered by a 200bhp V Twin
  4. cool. tis the future
  5. Fugly
  6. It will clash with my open face, waxed cotton Belstaff and plus fours. So I for one will not be purchasing.
  7. I wonder what would have happened if you'd phoned up Lotus and said you'd email them through a design for a Lotus super bike and they'd received that.
    I can't help feeling they wouldn't have got back to you.
    It must be someone's pet project. Someone who will soon be fired.
  8. Even if they does not see the light of day, it's great publicity for the Lotus name.
  9. It's publicity. Not sure how great it is.
  10. It looks like a Harley XLCR 1000 crossed with a brick !
  11. I agree. The maxim of "There is no such thing as bad publicity" is wrong in this instance.
  12. if they will by a victory chopper , they will by that.
  13. Briggs and Stratton driving a big eff off alternator.
  14. You really need to get out more. British designers are among the best in the bloody world. This isn't the work of any of them, it's the work of a student who once saw a Harley...
  15. On demand of Figaro I'll keep it short......its a bit shit.
  16. It's really no superbike is it.
    apparently a short production run (100 or 200 off?)
    ill be be honest, I reckon they could make it shorter and still have a couple to stick on eBay after 6 months in a lonely crate
  17. Maybe they will sell them all on eBay. It wouldn't be a lot dafter as a roll out plan than the bike is as a design.
    Sell bikes? Sure. But who is going to service them, who is going to sell them and what about all the back-up and spares? Why would you do this for the sake of 100 bikes?
    The people at Lotus are losing the plot.
  18. I,ve no positive comment to make on this "bike"
    Anyhow some specs for anyone who cares ..
    Lotus C-01*LOTUS C-01 TECHNICAL SPECIFICATION*Engine: 2-cylinder 4-stroke engine, 75° V-style*Capacity: 1195cc*Bore x Stroke: 105 x 69mm*Power: Approx. 200 HP*Transmission: 6-gear jaw-type shift transmission*Lubrication: Dry sump lubrication*Main shaft ratio: 40:76*Lay shaft ratio: 15:41*Cooling: Water cooling*Clutch: Hydraulic anti-hopping clutch*Frame: Aero tech steel/Titanium/Carbon fiber frame*Fork: Upside down*Suspension strut: Twin suspension strut*Spring travel front: 3.15 inches*Spring travel rear: 2.75 inches*Brake system front: Twin brake disc, 320mm, four piston calipers*Brake system rear: Single disc, 220mm, two piston calipers*Chain: X-Ring resp. O-Ring*Head tube angle: 59-degrees*Fork angle: 54-degrees*Wheel base: 64.7 inches*Ride height: 3.54 inches*Seat height: 27.95 inches*Fuel tank capacity: 2.77 gallons*Dry weight: 399 pounds*Wheel front: 120/70 ZR19*Wheel rear: 190/55 ZR17
  19. There's nothing "super" about any of that...
  20. It's a KTM RC8 engine
