1260 Multi Vibrations And Phone Cameras
Discussion in 'Multistrada' started by Andrei_Multistrada, Jan 30, 2022.
  1. They do, yes. however if you want to connect it to the battery (with or without the optimate and you want to have room to wiggle when hiding the cable) id suggest getting it from somewhere else as the Quadlock one is only 1.5m long.
    https://www.quadlockcase.eu/collect...less-charger-cable-kit?variant=39675449147474
    Also Id suggest the 90 degree bend on it as its much nicer and cleaner. Like this one:
    https://www.amazon.co.uk/UGREEN-Deg...1643735225&sprefix=usbc+water,aps,104&sr=8-10
  2. No. My KTM has a USB socket inside a weatherproof case, which I connected the charger to. You'd probably be looking at something along the lines of Andrei's suggestions above.
    From their site (my boldening)...
    Whilst some bikes have a USB port pre-installed, riders without this option will need to provide their own motorcycle USB charger. This needs to have a minimum power output of 5V 2A to power the wireless charger sufficiently. We also recommend QC 2.0 to achieve faster charging speeds if supported by your device.
  3. Do ignore this, I read the question in a weird way :) Gary is righ!
